Question about Char-Broil Advantage 463453306
I'm trying to replace the paddle burners on this grill, but I don't know how to get the old ones off. Char-Broil said I have to disassemble the entire firebox to replace them. Is this correct, or is there an easier way? Char-Broil Advantage grille model #463453305, serial #0506699156
  • 110 Answers
Hello, The model number that you gave is relatively simple to change the burners.
  1. Remove the 3 cooking grids
  2. Remove the 3 vaporizer tents
  3. Between each burner is a "pal nut" that just pushes on and will likely be destroyed when you remove it. They run a couple bucks each at Sears, part # 7000132
  4. This will release the carry over tube holding the burners down and the burners can be lifted out.
  5. Ensure that you clean out the carry over tube when you reassemble. This carries the flame from the first burner across to each of the rest of the burners when lighting them.
  6. Reassemble in the reverse order ensuring that you put the burner tubes over the burner valve tubes when reassembling.
You can find an exploded view with all the parts numbers at: http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001103_463453305_a.pdf
If this was helpful, please vote yes. Thank You!!
Posted on May 07, 2011
How to replace regulator/hose/valve assembly on char-broil gas grill?
Follow the hose back to where it connects to the gas rail , and go from there , to see what has to come off if anything .
Apr 21, 2013 | Grilling
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
Need a Burner Kit for a Char-broil 9000 DLX (Precision Burner)
You can order the burner directly from Char-Broil, if you have the correct Model Number. Go to
http://www.charbroil.com/Store/ReplacementParts.aspx
Hope this helped you. Please let me know.
May 08, 2011 | Char-Broil Grilling
Need to know where to connect igniter button to where side burner is still connected not main burners
According to your Owners Manual, the side burner uses the same electronic ignitor as the main burners. I know that sounds odd, but that's what Charbroil often does with their igrills.
To help you with further insight and in case you've misplaced your Owners/Assembly Manual, I have included a link to it that you can download and print for future reference, if you like.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001189_463453306_english_37f8ef8b-0_.pdf
Happy Grilling!!
Apr 23, 2011 | Char-Broil Advantage 463453306
Have model 463728504 char-broil withno manual and I do not knowhow toturn side burner on
Here's a link to your Owners Manual, that you can download and print for future reference. Pay particular attention to Page # 8 (lighting the burners).
Happy Grilling!!
Apr 10, 2011 | Char-Broil Advantage 463453306
How do youremove and replace a charbroil gas grill burner on model number 463268007
Here is a link to the Owners Manual for your model grill. It has the assembly instructions, so just reverse what they are and you'll be in business. As they say, "one picture is worth a thousand words."
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463268007%20manual%20-%20english_3d4c7147-c_.pdf
Apr 03, 2011 | Char-Broil Grilling
I have a char-broil Grill where the ignition wire came loose and do not know it came from
it come sfrom the ignitor on the burner or off the sparker /ignition button
May 20, 2010 | Char-Broil CharBroil 4637318 Grill
I'm trying to replace the burner on a Char Broil Master grill 7000
Should be able to get the burner assembly at any Lowes or Home depot store and not hard to change out. Old one lifts out and new sits right in. Hope this helps.
Mar 19, 2010 | Char-Broil 7000 Quick Set Gas Grill
Char Broil grill w/full tank and cleaned air jets, no heat
try opening the tank really slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Sep 17, 2009 | Uniflame FG2204C Grill
I have a char-broil 3 burner grill that is about 6 years old. It has 3 circular burners. The amount of gas now getting to the burners is equivalent to low even when the dials are on high. Do I have a...
most likely burner problem try removing burners (they generally just lift out or held by 1 or 2 screws) clean the sides of the burners with wire brush most likely then orifices on burners are clogged hope that works for you
Aug 23, 2008 | Char-Broil CharBroil 4637318 Grill
Char-Broil Advantage 463453306 Logo
378 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
