Question about Stihl Chainsaw Cutoff Saw Flywheel 08 S Ts350 P835
My stihl ts 350 cut off saw has no spark. having trouble finding any info
3 Suggested Answers
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
  • 14 Answers
SOURCE: stihl ts 350 super cut saw died in the middle of cutting a brick
i am doing one right now (ts350). I had no spark. 2 problems there. I had to replace on/off switch do to dust making it malfunction. still no spark so I had to replace the Ign. module. got great spark now. It's not cheap either ($226.00 canadian) had to order it from a dealer. Now I have no fuel getting to the cylinder so I have more work ahead of me. I hope this helps if you only have a no spark problem. It's about a 6 on the skill level.
Posted on Sep 21, 2012
No fuel to spark plug stihl ts400
could be fuel pipe bent/hole in fuel pipe or yes could be carb
May 20, 2014 | Stihl Concrete Cutoff Chop Saw Clutch...
Ts 410 won't start
check for spark, check for fuel, if you have both poss pot and piston
Apr 13, 2014 | Stihl Ts 410 420 Cut Off Saw...
Stihl ts 350 super cut saw died in the middle of cutting a brick
Can you get a compression tester to check the compression? With the throttle wide open, the choke OFF, and the decompression valve (if so equipped) NOT engage, pull the engine over 3-5 times or until the gauge quits rising. You would like to see 90psi or more and if it is at 60 or less then it is most likely a scored piston and cylinder or bad rings. If the compression is good you need to check for spark. If it has good spark then it will most likely be fuel related. Often a complete tear down and rebuild of the carb is what is required.
Jun 26, 2012 | Stihl Saws
STIHL TS760 cut off saw repair manual needed
Hello. Found the link for downloads, they also have contact info should your model not be online. http://www.stihlusa.com/information/info_product2.html
Hope this helped.
Mar 18, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
TS 350 I have spark to the on/off switch, but no spark to the spark plug
The Short Circuit wires need to be looked at. Take off the cover over the flywheel. The two thin wires coming off of the coil need to be checked to see if there is a spot that has rubbed off and if there is a bare wire grounding out against the housing of the Cut Off Saw. May also check the coil wire going to the spark plug. This can also develop a spot that can ground out on the housing.
Sep 17, 2010 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl 410 wont start put new spark plug but no spark
Try a new coil.Hope this helps and Thank You for asking!!!
Jul 19, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
Hi there; my stihl ts 420 does not start easily
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
Running bad with oil leaking out the muffler crimps. Too much oil in the mix? Cleaned the air filters already and checked the spark plug. Looks good, maybe the carb?
Check the spark arrestor screen and see if the screen has carbon deposits on it. If it does then you need to clean the spark arrestor screen and re install it in the muffler. You can clean it by burning off the carbon. The air filters on the TS 700 Cut Off Saw do not need to be cleaned, they only need to be replaced when the unit starts running poorly. The carburetor could have something in it that is keeping the needle from closing and flooding out the unit. I would suggest taking this unit to a Stihl dealer that has a Gold Certified Technician. You can use the dealer locator on the the Stihl USA website. I have included a link HERE. You can type in your zip code and it will tell you where the closest dealer is and what level of technician they have.
May 14, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
Stihl Chainsaw Cutoff Saw Flywheel 08 S Ts350 P835 Logo
425 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
