Question about Goodman GMS90703BXA Heater
I get a flashing light 6 times, says open fuse or rollout. I pull the fuse out and the blower goes on. No heat or blower when the thermostat asks for heat.
    Genius:
  • 1,478 Answers
I will advice you replace the fuse on your heater and see if it will produce heat.
Posted on Oct 04, 2010
I have a Amana unit Model# PGA60C1152F that has a blinking light on the control board it blinks 4 times. That heat will come on then go off but the blower nevers comes on.
look on the inside of the door that you took off and there should be a diagram and on that there will flash code that will tell you what 4 flashes means.i think it is a flame rollout or high limit.
Nov 16, 2012 | Amana Heating & Cooling
Tip
When the furnace blower runs all the time.
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Make sure the fan switch on the thermostat is not in the "ON" position it should be in the "AUTO" position.
on Dec 30, 2009 | Heating & Cooling
Open rollout or open fuse on Goodman
the fuse is located in the circuit board in the blower compartment and the roll-out is located in the burner section and can be a reset-able switch style or the one time fuse link style which is a a small silver cylinder and is mounted in a ceramic piece and is held in with one screw. Both of these are mounted around the opening of the your burner assembly near the opening. This will be near the area of the gas valve.
Sep 24, 2012 | Goodman Manufacturing Goodman R410A 13...
I have a Goodman GMH95/GCH9 furnace. The blower runs but no flame. LED is on (normal operation) checked fuse ok. held down fault button-6 flashes. didnt look like the draft blower turned on when a call for...
Hello, you can check the resistance of the motor by turning power off to the furnace and disconneting tje two wires which go to the motor. Take a meter and check the resistance, you should have resistance, if not the motor is bad. A rollout switch is a normally closed switch so you will chevk its resistance aswell, if the switch is open that signals a problem with the burner flames and you not read resistance. If the switch is closed and good you will read resistance.
May 01, 2011 | Goodman Heating & Cooling
What is code flashing 6 times mean?
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Sorry to read about your problem, I hope this helps you out.
Circulator blower runs continuously. No furnace operation. Integrated control module diagnostic LED is flashing SIX (6) flashes.
6 FLASHES
1 Rollout limit circuit is open.
2 Flame rollout. i? Misaligned burners, blocked
flue and/or air inlet pipe, or failed induced draft blower.
3 Loose or improperly connected wiring.
4 Check burners for proper alignment.
5 Check flue and air inlet piping for blockage, proper length, elbows, and termination. Correct as necessary.
6 Check induced draft blower for proper performance. Replace, if necessary.
7 Tighten or correct wiring connection.
Turn power OFF prior to repair.
i? See i?Vent/Flue Pipei? section for piping details.
i? Ensure the correct pressure switch replacement is used.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
Dec 29, 2010 | Goodman GMS90703BXA Heater
Model G5RA096C-16 motherboard light flashes one time pauses then flashes again and so on. The furnace turns on and blower turns on but does not heat. What does the flashing light mean?
Your furnace is off on a safety limit. Look for small thermal disks around the burner area they will have a usually red switch in the center and 2 wires coming into it. Reset this and watch furnace run. These are called rollout switches and they trip when you have flame rollout. SO WATCH IT RUN. If you have flame rollout you will most likely have a cracked heat exchanger if so you will need a new heat exchanger or new furnace. Next the number of flashes is important on some furnaces it will tell you what part is faulty. Count the flashes then on one of the furnace covers is the wiring diagram it will tell you what the flashes mean otherwise you can tell me and Ill help you out, WHen you reset the power on the furnace does it try to heat tell me what all happens when you shut the switch off then back on. when you turnit back on make sure the stat is calling for heat,
Dec 13, 2010 | Heating & Cooling
Tappan furnace blower will not shut off and furnace does not heat and red light is blinking one flash constantly.
Mar 12, 2010 | Heating & Cooling
Outside heating unit runs all the time
Feb 19, 2010 | Heating & Cooling
Arcoair central heat /air conditioning unit
The blower motor kicks on when there has been a 24 volt control failure.
This usually means that a limit switch has tripped.
Most likely that would be a high temp limit switch or a rollout switch.
First, make sure the filters are clean. and the evap coil is clean. If eaither are dirty/clogged, it will partially block airflow, causing the furnace to overheat, causing the high temp limit to trip.
A rollout switch typically trips for three reasons.
1 flame rollout into the burner compartment due to poor airflow.
2 overheating af teh metal plate the rollout is mounted to, due to dirty, old, rusted components.
3 a bad limit switch.
If your unit has an LED light, count the flashes and it will hepl popint out the problem.
(locate the wiring diagram/flash code list, and correspond the flash count, with the code.)
First, check filters.
Jan 14, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
52 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
