Question about Fisher and Paykel IWL12 Top Load Washer
Our wash machine will not run on fast spin. It shakes so much that usually one of the rods that the tub rest on will bounce out of it's holder. Do you have any ideas what is wrong?
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.I have seen this problem many times before and the problem is all or some of your suspension rods are faulty.They will need replacing.They are not that expensive and if you purchase a set of them I will guide you step by step in the replacement of the rods.The problem on the rods is the rubber plungers wear and the rod reacts like a faulty car shock absorber.I am nearly 100% sure on my diagnosis but the only way to be sure is to look at the machine.Although this problem is nearly always caused by faulty suspension rods, sometimes when there is water loss in the balance ring on the bowl this has the same symptoms.Lift the lid and rock the bowl from side to side and you should hear water up top of the bowl which is your balance ring.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Posted on Oct 05, 2010
My cabrio will not spin or complete a wash cycle. Acts like iit's unbalanced even when empty. Keep getting an F51 error code
it is most likely a bad center bearing. Was it loud when it sup last? If it was then the bearings are going bad. If not spin the tub by hand and see if its stuck if it is work it back and forth and see if you can break it free. That is still a bad bearing. Also try spinning the basket by hand as fast as you can and see if the bearing sound like they are grinding or smooth. If the bearing seem ok then push down on the tub ring and try to push the tub and basket down it should take quite a bit a pressure to push the tub down is its easy and you can bounce the tub up and down it the washer like a basket ball then you need new support rod they keep the tub stable during spin and when the springs on these go bad they allow the tub to bounce during spin and that causes the unit to go out of balance and stops spinning.
Dec 23, 2016 | Washing Machines
Machine goes out of balance & vibrates on spin cycle
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Mar 19, 2015 | Washing Machines
I have a Samsung washer model number wf338aab/xaa my tub is off balance
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
By the way my advice is free cuz God is good!
Sep 17, 2014 | Samsung WF328AAW Front Load Washer
Why is my basket leaning to the side on my easing machine
Sep 06, 2014 | GE Washing Machines
Will not complete spin/rinse cycle - shakes big time
sounds like he just wants money? No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sep 04, 2014 | Whirlpool Cabrio WTW6600SG 4.6 Cu. Ft. Top...
Everytime it goes to spin it starts shaking real bad displays ul then ol not even anything in it i have pulled tub there is a crack in the piece with windings but not affecting windings
The ul and ol are unbalance load and over load.
I would suspect the suspension rods, if you look you can see the tub is suspended by 4 rods (10 in image) and spring loaded shock built into them.
The crack in the stator is nothing that should cause any worry about.
If the suspension rods, springs and holders are all okay the next likely suspect is the basket itself.
Apr 25, 2010 | Kenmore Oasis 27042 Top Load Washer
Spin vefy fast
A rapid spin cycle is actually a GOOD thing. This is an indication that the gearcase (transmission) and the drive motor are both running strong.
If the washer shudders during the spin cycle the first thing you need to do is check to ensure the washer is properly leveled. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The model Whirlpool top loader you have, has an auto-leveler mechanism on the back two legs that can become unlevel periodicailly. You should check the washer level from time to time when it is empty. You need to also make sure the washer is level in ALL directions (front-to-back and side-to-side).
Accidental unbalance problems that can occur from washing blankets, comforters, or heavy loads of towels can also cause the washer to become unlevel and shake. This can also contribute to the level mechanism becoming unbalanced.
Overloading the washer can also cause unbalance problems. Washing blankets or conforters can cause the load weight to shift to one side of the tub. This will result in a tub that shakes violently and bangs against the cabinet. You may have to redistribute the load weight when washing heavy items. This can also occur when washing loads of towels. This is NORMAL as some heavy items do not distribute the weight evenly.
Another problem (which is less common) that can contribute to wash unbalance problems is a weak floor under the washer. If the floor flexes (even the slightest) during the spin cycle, it can cause the washer to bounce or shake. Mobile homes or laundry rooms on the second floor of a home are notorious for having weaker floor structures. This washer has a 35 gallon tub capacity. Coupled with the weight of a wet load and the spinning action, this can put a lot of centrifugal force on a floor.
If you have any questions or concerns, please post back and let me know. I hope this information is helpful to you.
Apr 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
At the end of each spin cycle it knocks loudly
A Clothes Washer with the complaint of "excessive noise & sssshaking" can typically be a couple of things;
Un-level Washer (Very Likely) - I would level and adjust your legs on your washer appropriately. Make sure when your slighly "push test" your washer, you have no machine movement, rocking or tilting. When the machine is going into the final rinse/spin cycle, the tub can rotate fast and if the washer legs or even the floor is slightly un-level, this can result in your washer to become noisey, shake, etc and can further cause the unit to break-down and no longer spin.
Un-balanced Load (Likely) - Ensure you are loading the washer and distributing the clothes (weight) evenly as this may cause the tub to spin improperly at final spin cycle.
Broken Drum Support/Springs (Likely) - Can be 5" black supports located at inside - top of tub area. Also, springs can also be located at inside bottom rear of machine holding the tub to the rear panel.
-C
Fremont, CA
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
93 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
