Cobra-sr900 reception Found instructions online to program this receiver,but no luck. Turn on press manual press ch. 1 press manual enter frequency 155.250 finish by pressing E for enter Nothing happens until I hit scan.It scans,but does not receive anything.The only thing I get is weather channel.Is this thing broke or is something else wrong? Would like to download operating instructions if possible.Thanks. Bob
Press E after the Channel # instead of manuel.
Posted on Oct 09, 2009
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
Please tell me how to program in my county scanner frequency numbers .
To enter a known frequency into your BC92XLT:
- Power the scanner ON
- Press the HOLD key
- Enter the number of the channel that you wish to program (1 through 200)
- Press the FUNC and PGM keys
- Enter the frequency, including decimal point (e.g., 155.455)
- Press E to enter the frequency into the scanner's memory.
More detailed programming instructions can be found in the factory user's manual which you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Oct 08, 2010 | Uniden BC92XLT Handheld Scanner
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
Trying to program it
First you'll need a list of frequencies to program. For a comprehensive database of active frequencies in your area, visit:
Once you have your freq list, power the scanner ON,and:
1. Press PGM. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the keys to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel. Press DELAY if you want the scanner to pause 2 seconds on this channel before it proceeds to the next channel after a transmission ends.
4. To program the next channel in sequence, press PGM and
repeat Steps 2 and 3.
Operation
• To listen to a weak or distant station, turn SQUELCH counterclockwise. If reception is poor, turn SQUELCH clockwise to cut out weak transmissions.
• If SQUELCH is adjusted so you always hear a hissing sound, the scanner will not scan or search properly.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
BillB
Jan 09, 2010 | Radio Shack Pro-2018 Scanner
How to program regency model 1070 scanner? I program scanner,yet unsure why no ''frequencies'' stop.Only zero flashes>
I couldn't locate a manual for you, but this vintage 10-channel unit is fairly simple to operate.
Start by turning the unit on with the POWER button.
Push the MANUAL button.
Push MANUAL until you see the Channel you want to enter the frequency in -i.e: Ch 1, Ch 2, etc.
Enter the frequency with all the digits needed - i.e: 44.94 / 44.98 / 154.965 / 155.610 etc
Push the ENTER button. The frequency will now be in the Channel "Ch" you chose.
While still in the manual mode - go the the channel you expect to listen to most - then push "DELAY/HOLD". This will hold the scan so you will get the reply from the dispatch unit to the receiving unit.You can set this feature on any or all of the ten channels.
Push the "LOCK" button to lock out channels you no longer want to listen to, or that you want to ignore temporarily.
Dec 09, 2009 | Radio Communications
Need manuel
The manual for the Uniden BC147XLT is not available on the Uniden website. Please contact their customer support via their website here: http://mycusthelp.com/UNIDEN/supportcontact.asp?sSessionID=&sEmail=
A few tips I found online:
Programming your scanner
1. Press Manual 1 Manual
2. Enter a frequency
3. Press E
4. Press Manual
5. Repeat steps 2, 3 and 4 as needed
6. When you finish the programming steps press Scan
Hope this helps!
Apr 27, 2009 | Office Equipment & Supplies
How do I program a BC155XL scanner?
I can't find a manual for this oldie, but generic Bearcat programming may work:
1. Press the MANUAL key to select the channel that you wish to program.
2. Enter the desired frequency, including decimal point.
3. Press the ENTER or E key.
4. Repeat the process starting with number 1.
Mar 25, 2009 | Delphi Roady SA10035 XM Radio Receiver
Cobra Police Scanner won't accept my frequency codes
when entering your codes make sure you put in the . or it will not take the number, most times the . is after first 3 # then hit enter then prg. I hope this helps.
k.ditterline@yahoo.com
Mar 09, 2009 | Uniden BC80XLT Handheld Scanner
Wanted manual realistic 2010scanner
The realistic 2000 series scanners do not have a "VFO" (variable frequency occilator) in the true meaning of the sence. This basicly means that they can only scan the channels or memories that you have programmed.
You can however set a low frequency (like 144 Mhz) and a high frequency (like 145 Mhz) and the scanner will "bounce" between the two, picking up anything in between.
Do you have the operating manual? If not, here is a copy
Turn on your Pro-2010 by rotating [VOLUME] clockwise. (When first turned on, your Pro-2010 may start scanning).
Rotate [SQUELCH] fully counterclockwise. You'll hear a rushing noise from the speaker. Slowly rotate [SQUELCH] clockwise until the noise just stops.
You're now ready to start entering frequencies.
Programming Frequencies
Before programming frequencies, make sure your Pro-2010 is turned on and the SQUELCH is adjusted.
Suppose you want to program Channel 1 to receive 162.55 MHz. Here's how you would do it:
1. Press [MANUAL] and select channel 1. You can do this in two ways:
press [MANUAL] continuously until the Display indicates Channel 1 or
by pressing [1] [MANUAL].
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency. In this case, press the [1] [6] [2] [.]
[5] [5] keys. Check the display to make sure the frequency it shows
is the one you meant to program. If it is, press the [ENTER] key.
4. To add more frequencies, just press [PROGRAM] to advance to the next
channel and follow the steps above.
5. If you ever want to change the frequency entered for a specific
channel, just enter the new frequency "over" the old frequency using
steps 1, 2, and 3.
Make a mistake while entering the frequency? Just press [CLEAR], enter the correct frequency and press [ENTER]. If you're entering a new frequency in place of an old one, the old frequency won't be "erased" when you press [CLEAR]. It will remain stored on that channel until you correctly enter a
new frequency and press [ENTER].
You'll hear a "peep" sound as you press the various keys. This lets you know the key has been properly "entered" into your Pro-2010.
Using the Scanning Function
Your Pro-2010 will automatically scan all the channels you've programmed and stop whenever it finds a signal. To scan channels, just press the [SCAN] key.
To stop scanning, just press [MANUAL] and you can select specific channels
you want to listen to.
IMPORTANT! Your Pro-2010 won't scan unless SQUELCH is set to the point where no sound is heard if a signal isn't being received.
Delay Function
When your Pro-2010 is scanning, it will stop whenever it finds a signal on a channel. As soon as the signal ends, the scanning function will resume. Most communications heard will be two-way. To make sure you don't miss any replies, press [DELAY]. This will cause your Pro-2010 to stay on a channel for two seconds after the end of a transmission, giving you time to hear any reply. To release the Delay function, just press [DELAY] again. The Delay indicator will show on the display when the Delay function is used.
Lockout Function
You may want your Pro-2010 to "skip over" certain frequencies while it's scanning (such as continuously transmitted weather broadcasts). To "lock out" such channels, follow these steps:
1. Press [MANUAL] to stop scanning. Continue to press [MANUAL] to
advance to the channel you want to lock out.
2. When you reach the channel, press [LOCK OUT]. The display will show
[o] to indicate this channel will be skipped over during scanning.
3. To release the lockout, press [MANUAL] to stop scanning. Advance to
the channel that is locked out and press [LOCK OUT] once again. [o]
will disappear from the display.
If you use the lockout function on all channels, scanning will be impossible - you'll only be able to change channels using [MANUAL].
Speed Selection
Your Pro-2010 will normally scan channels at a rate of four channels per second. If you press [SPEED], channels will be scanned at a rate of nine per second. Press [SPEED] again to return to a rate of four channels per second.
Priority Function
You might want to scan other channels yet not miss a call on a channel of particular interest to you (police, fire, ambulance, etc.). The Priority function will let you scan other channels - but if a call is received on the Priority channel, your Pro-2010 will automatically switch to the
Priority channel!
1. Only Channel 1 can be used as Priority Channel: Key in the desired
Priority frequency into Channel 1.
2. Priority function works only when the unit is in Scan or Manual mode.
3. Press [PRIORITY] to start Priority function. A [P] will appear on the
display.
4. Press [MANUAL] or [SCAN] to listen to other channels. Your Pro-2020
will check the Priority channel and switch to it if a signal is
received on it.
5. To cancel Priority function, press [PRIORITY] again. the [P] will
SEARCHING WITH YOUR PRO-2010
One great feature of your Pro-2010 is its ability to "search" for frequencies being used. This means you can hear all the action on the airwaves in your area! To use this great feature, just follow these steps:
1. Press [PROGRAM] key.
2. Press [LIMIT] key. Enter the lower limit of frequency range to be
searched (such as 45.00 MHz). Press [ENTER].
3. Press [LIMIT] key again. Enter the upper limit of frequency range to
be searched (such as 46.00 MHz). Press [ENTER].
4. Press either [up arrow] or [down arrow] to start Search. [Down arrow]
will start search from the highest frequency and go down. [Up arrow]
will start from the lowest frequency and go up.
5. You can control the speed of the search by using the [SPEED] key to
accelerate or to slow down the search.
6. Search will stop when a frequency is found with a signal. To restart search, press [up arrow] or [down arrow]. In Program Mode, search range will be displayed each time [LIMIT] is pressed. It is impossible to change the lower frequency only: to change lower frequency you must change higher frequency first. The higher frequency can be changed any time.
Storing Frequencies
If you want to enter some of the frequencies found during search, do this:
1. Press [MONITOR] when your Pro-2010 finds a frequency you want to store.
2. Use [MANUAL] key to select a channel to enter the frequency your Pro-
2010 found. The display will show the frequency currently stored on
the channel, but don't worry - the old frequency will be erased when
you start to enter the new one.
3. Press [PROGRAM].
4. Press [MONITOR] again. The new frequency found during the search will
be displayed.
5. Press [ENTER] to put the new frequency into the channel in place of
the old frequency.
6. Press either [up arrow] or [down arrow] to resume the search. To
return to manual or program operation, press [MANUAL] or [PROGRAM].
To resume the search from one of the limit frequencies, press [LIMIT]
and then [up arrow] or [down arrow].
Error Indications
Sometimes when you try to enter a frequency for a channel or as a search range limit, you may find an ------ on the display. This means the frequency is in error and you won't be able to enter it into your Pro-2010. Such frequency errors usually mean you've entered a frequency outside the ranges your Pro-2010 operates on (such as 225.00 MHz) or you've put the decimal point in the wrong place (14.682 MHz instead of 146.82 MHz). Check carefully to find your mistake and then press [CLEAR]. You can now enter the correct frequency.
Hope this helps,
M3ODQ
Feb 01, 2009 | Radio Communications
How do you program a bc560xlt scanner
Hello sir,
Check out this link for the programming...
http://www.grove-ent.com/SCANNERPROGRAMMING.htm
http://www.icehouse.net/no7up/bc560xlt.html
bye
Good Luck
Don't forget to rate the solution
Mar 11, 2008 | Audio Players & Recorders
513 people viewed this question
 Grubhead
Grubhead
