Question about Emerson SpongeBob SquarePants TV
I can't get DVD to play on Tv
I bought the TV used, the DVD player did not work, i tried to put another DVD player on, but cannot figure out why DVD won't work. i used the remote to change to AV (alternate video) but the DVD still doesn't show up. I have changed the jacks every which way I can change them and still no DVD watching. Can anyone tell me what i am doing wrong? I wish I had the book to this TV, that might help.
  • 6 more comments
  • Anonymous Jun 08, 2008
    same exact problem
    same exact problem
  • riddlegirl Jul 14, 2008
    I have the same problem but this is a dvd combo and it won't work. It played 2 dvds at first and now it just says loading.
  • Akrondionne Aug 09, 2008
    I have the same problem I brought used and played dvd for about 5 days now it says loading for about 2 min then it says not disc even when there is a disc in the player any solution please?
  • Jilleane Aug 14, 2008
    I bought this TV new and after about two months had the same problem. We still cannot play DVD's on this set. Really a waste of money.
  • Anonymous Sep 07, 2008
    Bought the same tv/dvd combo and have the same problem. It worked for a few days but now the dvd screen doesn't even come up. Even the menu is missing the dvd option. Is there someone out there that knows how to fix this problem.
  • shawneyh Oct 03, 2008
    Same problem, it won't acknowledge a dvd player I just get floating spongebobs across the screen. Doesn't matter what channel what AV nothing responds. I bought it for homeschooling. big mistake!! shawney
  • jeannettejoy Jan 05, 2009
    same problem and tried what you said here
    (make sure you have the rca jack from the dvd player to the tv yellow isVIDEO while red and white is audio(doesnt matter on a small tv set likethat for audio) if only one audio jack then just use the white one)
    Didn't make any difference ..does not read the DVD (if hooked up it will show DVD screen)
    so what is next??
    maybe there our hidden settings within the TV its self ???
    I have the same TV in pink and it works great with games and DVD players .. seems spongebob TVs are set to only run the DVD that comes with it??
    any other ideas??
    Sergeant:
  • 284 Answers
Make sure you have the rca jack from the dvd player to the tv yellow is VIDEO while red and white is audio(doesnt matter on a small tv set like that for audio) if only one audio jack then just use the white one
Posted on Jun 14, 2008
I can't get the DVD player to view dvd on tv
hi konni.
this is all i could find .
DVD player not working with TV By Charlotte Parker 25 Aug 2017
You've got your Sky Box, your TV, your DVD Player and your surround sound; you've also got your digi-box, your DVD recorder, Blu-Ray Player. With all that equipment, if something goes wrong it can be tricky to track down the issue. This article explains why your TV isn't playing DVDs and how to get it sorted out.
Figuring out the problem
Figuring out why your DVD Player isn't working with your TV is a process of elimination, so work through the steps below to figure out the cause of the problem.
The problem could be:
  • The connector cables/connections.
  • The DVD disc itself.
  • The DVD Player's optical reader (the lens which 'reads' the DVDs).
  • The TV.
Before doing anything, check all your connector cables. Make sure that all connections are in properly, and that the cables are in the right place.
One of the most important connections is the cable that runs between your TV and the DVD Player. If it isn't in place, then your TV can't read the information from the DVD Player and the film won't appear on your TV.
The DVD disc itself
Check for scratches, chips, smudges and any other marks. Test the disc isn't the problem by trying a different one in the player. If the new disc works, then the first one might need replacing.
The TVTry changing channels. Lots of TV's have a default channel specifically for DVD players. Have a look between the channels to see if the DVD menu appears.
On modern televisions, especially those connected to Digi-boxes or Sky Boxes, there's usually a 'Source' button on the remote control. Find it and go through until you reach the right setting for playing DVDs. To go back to watching normal TV channels after the DVD has finished, go back to the source button and change back to the original source.
That should be all you need to know to get your DVD player working with your TV
if none of above works then try putting a lens cleaner through it to try and clean the lens that reads the disc.
Nov 05, 2017 | Televison & Video
We have a spectroniq pdv-768. When we put in a disc and it try to load it it come back and says WRONG DISC. How do we get it to read the disk and play?
If your dvd player on your flat panel tv says "wrong disc" then it usually means that the format used to create the disc is not compatible with your player. Read the manual that came with your tv to figure out what file formats are acceptable for burned discs. Try another disc. Verify with a store bought disc that your player works. If it plays regular discs and not home made or burned media, then you will know that its just the file format used when the disc was created that is causing the issue.
Jul 17, 2011 | Televison & Video
We have a 23" Toshiba with a internal DVD player.
No,tv internal DVD player are not on sale by itself as a seperate unit,only can buy it from the tv corporations themselves and it not cheap and have to have experience to putting it in into the tv internal tv itself.The tv internal DVD player now,could be the laser eye data reader have problems reading mp3 and mp4 files on the DVD disc,which are video files.Now tries to play more than one DVD movies dic,tries like to play like 5 to 6 original DVD movies.One disc don't play tries another DVD disc.Tries this might forcing the laser eye reader to read DVD dics again and than might fix it to read video files again.Or just buy an external DVD player hook it up to the tv and play DVD disc on to the tv video modes.DVD players external devices are really cheap these day,like can buy new one for $40.
Mar 25, 2011 | Toshiba 23HLV84 23 in. TV/DVD Combo
No sound when playing DVD from Power Acoustik DVD to Jenson TV
My first question is on the main radio is there any aux, or any switch or if you plug headphones in to it do you get sound
Jul 19, 2009 | Power Acoustik PMD-100NT Car Video Player
American DVD discs will not load and play, but overseas discs will
no the coding would not change from using the dvd's from overseas. the ones that you say are american may not be american and that is most likley the problem. try putting in a dvd that you have had for a long time that you bought here in the states and if that works then the dvds you say are american are the problem.
May 31, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Tv and dvd remote controls interfere with each other
found out that signals from both remotes were on same waveband
moved dvd player tp differnet tv in diferent room and bought new dvd player to couple with LG flat screen
Not a technical solution bit did the trick
Ray
Dec 08, 2008 | Televison & Video
UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Jun 06, 2008 | Televison & Video
I can't play any DVD's. It keeps saying cannot read.
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Panasonic DMR-ES25 DVD Recorder
Emerson SpongeBob SquarePants TV Logo
187 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
