Question about Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX Zoom Nikkor Lens
Zoom mechanism making noise
my 18-70 's zoom mechanism has gone bad. It works, but makes a grinding noise when used. It was smooth for about a year. Is it bad? Can it be fixed by myself? is it going to cost me big $ to get it repaired.
thanks,
Pavan
  • pavanpeddu May 28, 2008
    Thanks Lee. I will try these and let you know. It still works, takes a little more effort to twist the zoom ring and then ofcourse the grinding noises.:-(
  • Abdulkader.Abdulhusain Goryawala
    I am having 18mm-135mm Nikkor lense fix on D-200 Nikon SLR Digital Camera having same bird chirping noise when I Auto focus and focus is not locking it locks when I use wide Angle but does not lock on Close up lens is going inside out and make sound like bird chirping so please give me the solution I think Auto focus mechanism is at fault or Auto Focus sensor chip does not locked SWM motor to exact Focus point. Please give me proper advice what to do. my E-mail adress is abdulgori@yahoo.co.in
  • 426 Answers
Well i had the same issue and i just slammed it (carefully of course) on the desk and it started working.... does it still zoom or does it just click and grind? also try zooming in and turning the lens faster outward or the oppsite direction to see if you can jump it back into the correct place on the gears.... my best guess is that it got dropped or the kids sat on it... and it made the gears slip into a bad place....
Lee
Founder Of Free Tech Associates
www.whypayforhelp.org
Posted on May 27, 2008
  • Lee N.
    Lee N. May 28, 2008
    ok let me know if you need anymore help please rember to rate the solution feel free to e-mail me at fixya@whypayforhelp.org
After installing new front rotors and pads on a 07 Mercury Milan there is a bad grinding noise
Hi Julie, Check the back plates behind the discs. Some times after working on the brakes the back plates are bent and cause the sound you're reporting. The ABS rotors, if correct should not come into contact with the sensors. Are the brakes efficient when applied? If not make sure they have been installed the correct way around. I have known mechanics to fit them with the metal part of the pad rubbing onto the disc! Anything is possible. Regards John
Jun 24, 2012 | Cars & Trucks
It's making a grinding noise.
It's the zoom mechanism. You either have dirt / sand trapped in there or the gears have broken.
Nov 26, 2009 | Sony Cybershot DSC-T200 Digital Camera
Lens makes grinding noise
yes dust in mechanism or broken gear but ti not easy
Oct 12, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
Grinding noise in front end
Hi
Had the exact same problem, on a used 2003 Protege ES with 82,000 miles that I purchased.
Started with the loud "road noise" I thought well maybe thats just the sound that it makes.
And then noticed that it varies when turning.
This will continue to get worse and then your abs light will come on when it gets bad enough to trigger the sensor..
It turned out to be a bad wheel bearing.
Take it to a shop and have an experienced mechanic check it out. Its repairable.
Apr 04, 2009 | 2003 Mazda Protege
Office chair makes grinding noise when I sit down or get up.
Hi this is Sachin , spray on the piston the silicon spary and leave for some time the grinding noise will be eliminated
Nov 05, 2008 | Plumbing
Zoom
Lens probably got off its track. you need to take the front case apart and pull out the 3 lugs at the base of the outer lens. YOu should ba able to manage to get the outer lens off, dont worry about breakin git as the stuff is made of heavy plastic. If you get it off, see if the inner barrel rotates smoothly. YOu will be actig on a small motor so youll feel a little resistance, but it should be fairly easy to rotate. Lube the helical tracks with heavy white lithium grease and put the outer lens back on making sure to align the tracks, press the lugs back in and reassemble. worth a shot. I did mine and was successful. See my folder on the C8080 http://picasaweb.google.com/pishta68/8080lens/photo#5199141246863292738
Apr 24, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
3040 Issues
A stuck pixel on the LCD is quite common. I have one on my 2020z; lot of people here would tell you the same thing. Long as it's just one, I wouldn't bother trying to get new camera. Far as the lens extension sound: It is a little loud, but a *grinding noise* doesn't sound normal. Go to a store and pick up another one, see if it makes the same sound. If not, you may have a bad camera.
Sep 07, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX Zoom Nikkor Lens Logo
434 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
