Question about Hitachi 60SX12B/13K 60" Rear Projection Television
JVC AP48WP34 No Menu
This set was out of convergence. I replaced the STK's.
The red is still out. I will recheck the resistors. I notice there is no MENU.
A black box appears when I try bring up the menu.
Any ideas on this?
TIA,
Peter
  • Hitachi Master
  • 8,617 Answers
Check the wire clip that runs from the convergence board up to the small vertical board that stands up on the large signal board. That clip plugs into the top of that small board the small board that stands up is what controls your menu.
Posted on May 27, 2008
My picture has a red and blue seoaration that looks like an old 3d film
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Feb 25, 2011 | Sony KP-51WS500 51" Rear Projection...
Sony model #kp51ws500. Common problems for screen appearing warped
Need more details about how the screen is appearing warped.
if you have color separation and distorted image (warped,bowed, etc), then your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless.
Note: The STK chips are black about 3 inches long and will be mounted against a large aluminum heat sink (metal fins). They have about 20 pins on them. I believe they are STK392-560s in that set.
I have sony tv kp-65wv600. It has problems. color and video is blurry, double vision, letters are curved
You have a convergence failure.
Convergence IC failure is very common. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Feb 24, 2011 | Televison & Video
The picture is producing a double image which appears to be in red only with a slight bending of the images on some parts of the screen.
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Feb 20, 2011 | Panasonic PT-47WX49 47" Rear Projection...
The picture is warped red & blues distorted
Try This:
Note if one STK chip fails, you replace both regardless. They will be right next to each other.
Feb 20, 2011 | Toshiba 57H81 57" Rear Projection...
I have what appears to be shadowing of the words.. and picture.. blue wave across the top of picture..
Your Convergence ICs are likely failing. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Feb 20, 2011 | Hitachi 57SWX20B 57" Rear Projection...
At times the screen becomes double
When you say "double" do you mean you see the colors somewhat seperated or see maybe blue or red outlines around objects? Does the screen distort?
If so then:
Your Convergence ICs are likely failing or it is a bad solder joint related to that area. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Note if one STK chip fails, you replace both regardless. There may only be one STK chip in this set. If there are two, they will be right next to each other.
Feb 20, 2011 | Mitsubishi WS-55857 55" Rear Projection...
My 65 inch sony tv half the screen is having colors like 3 d
Try This:
Feb 20, 2011 | Sony KP-51HW40 51" Rear Projection...
Picture is no longer working properly. Picture is blurry and colors are all wrong. Ghost image. Happened all at once not gradually. What needs fixed mitsubishi 65" medallion series. appox 7 yrs old
Try This:
Feb 19, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Picture shadowing and waving pictures
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 19, 2008 | JVC AV-48WP74 48" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
