Have a Selectric III. The black "U" shaped or "wishbone" plastic that guides the ribbon next to the platen has come loose. Can't figure out where it attaches or where the tension points are to hold it in place. I do not have access to another typewriter to see how this piece fits. Does anyone have a photo of the mechanisms before the ribbon is put in place? Trying to avoid a service call on something that should be simple to fix...? Thanks!
  • 3,594 Answers
Because it is a selectric III it can use 2 different ribbons. one the ribbon guides are part of the cassette the other the ribbon guiges are part of the typewroter. If it isthe first just replace the ribbon if it is the other you will probably need the lifter arm assembly.
DickyO
Posted on Oct 04, 2010
What would cause the ribbon guide to not lift to ball strike position?
Check ribbon adjustment there is an adjustment lever that adjusts the ribbon up and down.Also check that the ribbon is still good not wore out,out of ink.
Jun 27, 2014 | IBM Correcting Selectric III Electric...
How can I determine whether my typewriter is a Selectric II or III?
The video shows the models C, Selectric I, and Selectric II.
If your typewriter doesn't compare to any of these in the video it is most likely a Selectric III.
This will also help:
The Selectric III featured a 96-character element vs. the previous 88-character element. IBM's series of "Electronic Typewriters" used this same 96-character element. The 96-character elements can be identified by yellow printing on the top plastic surface and the legend "96," which always appears along with the font name and pitch. The 96- and 88-character elements are mechanically incompatible with each other (they won't fit on each other's machines) and 96-character elements were not available in as many fonts as the older 88-character types.
Jul 09, 2013 | Office Equipment & Supplies
My ibm selectric ii type impression is messy and sometimes missing part of the letters. I have check for proper ribbon placement and cleaned the ball element, but the impressions are still dirty looking. ...
Left Rear chrome lever with ABCDE or - marks should be towards the typist and the red ball next to the typing ballo should be moved to a higher number. Messy printing is caused by paper not being held tight against platen(black roller)
Jan 31, 2013 | IBM Correcting Selectric II
Selectric III typewriter
Go to lexmark.com and click your way to publications there you will find a manual with pictures and instructions on the ribbon.
DickyO
Mar 14, 2010 | IBM Office Equipment & Supplies
I Have an IBM selectric system/2000 Wheelwriter 3
The platen probably worked itself out press firmly down on both ends of the platen it slould click into place. If it won't stay you will need a platen.
DickyO
Oct 23, 2009 | IBM Office Equipment & Supplies
How to install a ribbon in an IBM selectric II typewriter
Pull the orange lever located on the carrier to the side. Make sure the ribbon passes through the ribbon lift guide next to the platen. The ribbon should go behind the the thick part of the guide and through the fingers to the inside on the outside of the guide. There is a wire (usually with a white platice roller on it) sticking up from the carrier. Maker sure the ribbon goes aroung the outside of the wire. Snap the ribbon down on the carrier then close the orange lever back in place.
Jun 26, 2009 | IBM Office Equipment & Supplies
Changing typewriter ribbon in the IBM Selectric
You haven't told what model of Selectric. If it is a selectric II or III, there is an orange lever on the carrier that you must pull to one side. The correction tape has a silver lever next to the take-up spool that you must pull outward.
Mar 11, 2009 | Office Equipment & Supplies
Don't know how to load and string the ribbon on an ibm selectric
Selectric III has two different ribbons the selectric II ribbon tha the ribbon guides are part of the macine and the "bicycle" ribbon that has the guides bilt into the ribbon. to replace the "bicycle" ribbon move pull the red lever on the right toward you, drop the ribbon in turn the knob a few times in the direction of the arrows, move the red lever back done.
The other style move the lever, drop the ribbon in, be sure the ribbon is left of the slacker finger sticking up on the left,thread it tru the guides, turn the knob inthe direction of the arrows, move red lever back,done.
DickyO
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectra III typewriter
There are two different ribbons for selectric III T/W's. One has the ribbon guides as part of the cassette the other the guides are part of the machine.
Be sure the ribbon and L/Oare installed properly and the ribbon is winding on the take up spool properly (counter clock wise) and if the guides are in the machine id to the left if thr white slacker finger just L. of the ribbon also be sure the L/O tape is behind the black seperation finger and the ribbon is in front of it (just to the rt. of the opening in the plastic card holder).
DickyO
Oct 30, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Selectric III Typewriter Ribbon help
There are two different ribbons for the selectric III one has the ribbon lift guides built into the ribbon the other the guides are part of the typewriter. The first is a General Ribbon T=387 the other is a G.R. T-385.
Hope this helps;
DickyO
Sep 01, 2008 | Lexmark Wheelwriter 15 Series II...
85 people viewed this question
k24674
jasbo
jasbo
