Won't power on
I have a Gateway 500 Media Center, it was on a surge protector(but not the telephone line) it does not have any power when I tried to start it the day after a thunder storm. I tried a new power cord, everything else still works on the surge bar, I put in two power supplys(didn't do any thing) tried a new power button(it had stuck before) still nothing. The monitor has a black screen that said no signal. The only thing different was about a month ago I in stalled a range extender but everything had worked fine since. Any ideas would be appreciated.
    Sergeant:
  • 336 Answers
Have you checked if the outlet has power? If so That is not good because that means that the Power supply is shot, or some other component is shot. If it has no power reset the circuit breaker.
All The Best,
RCF
Posted on May 28, 2008
MFC-8710DW has no power
If your Brother machine does not appear to have power,then check whether or not the date and time appear on your Brother machine's LCD. If anything is displayed on your Brother machine's LCD, then it is most likely receiving power.If your Brother machine's LCD is blank, continue to Step 2.
Verify the Brother machine's power cord is connected securely to the power outlet. If you are using a surge protector, extension cord, or power switch, disconnect it and plug the Brother machine directly into the wall outlet.
Please note Brother strongly recommends that you connect your machine to a surge protector.Because To protect your investment against power surges and lightning,
In particular, we suggest that you use a surge protector that is compatible with both standard A.C. power cords and telephone line cords. Surge protectors equipped with telephone jacks will assist in insulating your machine from any power surge that might travel through a telephone line.
If the Brother machine is turned OFF, its LCD will be blank. Please make sure the Brother machine is powered ON by pressing and holding the On/Off or Power Save key. This key is located in the upper-right corner of the control panel.
If your Brother machine's LCD is still blank, connect it to a completely different, known working power outlet. If the Brother machine powers up, then the problem is related to the original outlet.
-OR-
Confirm the power outlet is working by plugging another known working device (a lamp, radio, etc.) directly into the same outlet. If the other device does not work, the problem is related to that power outlet. If a wall switch controls the outlet, verify that the switch is ON.
If your Brother machine still will not power on, please contact Brother Customer Service.
Or
Please Follow Us On Brother Printer Support
Jan 02, 2014 | Brother printerall-in-onelaser mfc8710dw
Won't boot
3 BEEPS --RAM HAS IT HAD A POWER FAILURE AND DO YOU HAVE A SURGE PROTECTOR IS THE LIGHT STILL ON TO SAY SURGE PROTECTED
Apr 06, 2012 | Gateway GM5442 PC Desktop
My Gateway Essential 450 won't turn back on from the front power switch. Where can I buy a new switch or is the problem something else?
This is where you can buy a new ATX power on switch,
http://www.axiontech.com/prdt.php?item=78201
The Power On switch is located inside the plastic Power On button assembly.
Age plus the heat developed inside the computer, have made the plastic of the Power On button assembly, brittle.
I suggest removing the Power On button assembly from the Front Panel.
(And disconnect the Power On switch cable from the motherboard.
BEFORE you do I suggest you make a drawing, and possibly some notes, as to where that cable's wires plug into the motherboard)
Computer unplugged from power, follow Anti-Static Precautions.
I would suggest using a hairdryer set to low heat, and moving the nozzle slowly back, and forth at the plastic until it slightly softens.
(Or you can use a bowl of VERY warm water. The switch is no good now anyway)
Is the problem something else?
It's either a bad Power On switch, or a bad Power Supply.
(Provided you are sure the surge protector is getting power, AND you have ensured that THE receptacle in the surge protector that the computer is plugged into, has power.
I have had a few surge protectors where just THAT receptacle was bad. Surge protector power LED light was on. Monitor, printer, and router had power. Just ONE receptacle was bad)
There is a simple test to perform to see which component is bad Power On switch, or Power Supply.
IF you do not know how, and wish to, please state in a Comment.
Regards,
joecoolvette
Jun 15, 2011 | Gateway Essential 450cs Deluxe (ESSENTIAL...
My parents have a Gateway desktop with Windows Media Center 2005. It is plugged into a surge protector. Yesterday morning they experience two short power outages within one minute of each other. Now their...
When a desktop computer continuously restarts, it is typically an issue with the computer's power supply not being able to put out enough power to boot up the computer. (It takes more power to start the computer and get everything loaded than it does to keep it running.)
Usually this is caused by a faulty power supply, and the easiest solution is to replace it. New power supplies can be purchased for $30-$50... just make sure you get one that is compatible with your computer.
However, if you're having power issues as well, you might want to check the outlet where your computer is plugged into if you have a voltmeter or multimeter. If the voltage coming in isn't within the standard range (about 120 volts, plus or minus a few) the power supply won't be able to work correctly.
Your surge protector might also have been fried. Try plugging your computer directly into the wall outlet (bypassing the surge protector) and see if that makes a difference.
Sep 17, 2010 | Microsoft Windows XP Media Center Edition...
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
Need replacement Gateway 500 Media Center motherboard
Well of the 4 things needed for a pc to power on and work, you have replaced two. Next would be the mother board or CPU so if you have spare parts to test with I would try those.
Apr 02, 2010 | Gateway (4000274) Motherboard
Gateway 830GM won't turn on
it is an internal problem,your SMPS (Switch Mode Power Supply unit) is gone bad,only by changing SMPS..your computer will turn on for sure,, thank you, Plz rate me...
Jun 29, 2009 | Gateway 830GM PC Desktop
Computer power won't turn on
First thing to do is try to plug the pc in another wall socket to see if it goes on, If not, the MB could have gotten fried, even though the other plugs seem to work. Hopfully you just need another surge protector as that could have gotten damaged.
Jul 20, 2008 | Computers & Internet
Power outage, now pc will not power up at all.
sounds like the surge protector didn't protect. I would change the power supply.
Jun 12, 2008 | HP Media Center m7060n PC Desktop
OK FIRST A POWER SURGE PROTECTOR WILL ONLY PROTECT YOU 7 % OF THE TIME, WHICH YOU JUST REALIZED. SO YOU NEED TO BUY A BATTERY BACKUP ALSO KNOWN AS A UPS.... I CANNOT STRESS THIS ENOUGH. BRING YOUR PC TO BEST BUY AND THEY WILL TEST YOUR POWER SUPPLY, IF IT TESTS OUT OK THEN YOU BLEW SOMETHING IN YOUR MOTHERBOARD. GET A BATTERY BACKUPS/UPS!!!!!!!!!!!!!!!
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
