Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Bissell lift-off revolution, prematurely turns off after few minutes. Any ideas as to why?
    Novelist:
  • 171 Answers
HI there SmartAlec from NelsonVacuums.com.au here. Nine times out of ten this will be an overheating problem. There are two common causes, the first is that you have a blockage in the tubing before it gets to the dirt chamber. It is pretty easy to see if you have a major blockage, simply put some colourful paper (cut small like confetti) on the floor and vacuum it up. If it comes to the chamber or bag pretty quickly in about the same quatity as you put on the ground this is not your problem. The second cause is that you may have a blocked inlet filter, from memory on your model there is a filter "drawer" either above or below the canister. Simply remove and clean to restore your suction and stop the auto shut off feature.
If the filter is really bad or it hasn't been cleaned in a long time then it is worth replacing.
NelsonVacuums.com.au have a full range of filters for you machine.
Hope this helps.
Regards SmartAlec
p.s. Happy Vacuuming!
Posted on Oct 05, 2010
I have a Bissell lift-off revolution. The power won't turn on at all. Tried different outlets. It doesn't work whether the lift-off canister is out of the frame or in the frame. The manual refers to a...
I have the same issue too. Brush motor is working and brush is turning on but the vaccum motor is not working. If I take the canister out of the frame then it wont turn on at all. Any help?
Jul 15, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Brush wont go round but the belt is ok
The belt may look okay but it can still be stretched. If it is stretched it won't turn the brush against the resistance of the carpet. Here is a link to the belts you need and to the manual which has instructions:
Bissell Lift-Off Revolution Belt & Manual
Nov 23, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
My bissell lift off will not pick up, there are no blockages and suction is still strong
You can fix it easily. All you need to do is change the belt and you'll be good. Here is a link to the belt you need and the manual which has instructions.
Bissell Lift-Off Revolution Belts and Manual
Bisslll Lift-Off Revolution User Guide
Nov 15, 2009 | Bissell 3750 Lift Off Bagless Upright...
Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Jan 04, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
I cant find my manual to clean my Bissell lift of revolution
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jan 03, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Lift Off Broken Belt and Brush Roller
I had the same problem. I found that the brush actually melted to the end cap (the one with the square/ovalish end). I was able to pull it off with some force and applied some WD-40, but that only worked for one more use. The brush has again melted to the end cap and it is too deformed to try and fix. I suppose I will have to search for a new brush, but this model obviously has some innate flaws.
Feb 14, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
80 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
