Question about Kenmore 700 6972 Dryer
Dryer squeals and squeaks while running - Kenmore 700 6972 Dryer
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Posted on Oct 04, 2010
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Squeak
Pinot, usually the squeak on these 417's is coming from the drum ball and plastic bearing. Sometimes they crack and sometimes just need to be greased. Go to this link http://www3.sears.com/ and enter your model number, upper left hand corner. Follow the link and click on view diagram, page 1. Look at number 12 and 34. This is the drum hitch and plastic bearing. Your husband will have to remove the top and once he has the belt off, pull up on the drum to get it off the bearing, (plastic coupling that the ball sets into. If it's not cracked and the ball is is good shape, just grease it. If it's cracked and the ball is a chewed up, replace them both. This job is done better with 2 people cause it's not the easiest deal. You can find the part numbers on the parts link right next to view diagram. Let the cat know if you need any more help, Catriver.
Posted on Jan 06, 2008
  • 38 Answers
SOURCE: Inglis Citation dryer still squeaks
just an idea.....try to match the squeak to the revolutions of the drum or the guide pulley.
if the squeak is fast it is probably a guide pulley or a roller that the drum rides on. if the squeak is farther apart then the drum is wearing in one spot and rubbing on something. check for wear spots around the drum area.
hope this helps.........jay
Posted on Mar 21, 2009
  • 18 Answers
SOURCE: Dryer belt squeaks
I've had "squeak" problems in the past with my Maytag gas dryer. It sounds like either a dry roller bushing (there are no bearings), an incorrectly installed belt (e.g, routed over belt tensioner instead of under), or a dry idler pulley. Since you did not indicate that you had recently replaced the belt, I would rule the second cause out and concentrate on the dry roller bushing or idler pulley. For both, a high temperature grease is recommended, since the right roller is located just above the burner cone and is subjected to heat.
Posted on Oct 24, 2009
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
Why is dryer squeaking,belt sprayed but still squeals.
If the belt is to lose it can slip and squeal. worn out belts do the same.
Jul 12, 2014 | Eureka 431BX Bagless Upright Vacuum
Dryer
Squealing could be a loose belt very seldom see this squeaking more than likely the drum rollers
Mar 22, 2014 | Kenmore Elite HE4 Electric Dryer
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
Inglis dryer is squealing like a belt loose. it subsides during cycle but a burnt rubber smell is very prominent when finished
Replace the belt - it is old and worn out. The belt is made of rubber and is slipping, causing the smell and squeak. The belt heats up and becomes more flexible after the dryer runs a while; this is why the squealing stops.
Mar 26, 2013 | Inglis 6.5 Cu. Ft. 5-Cycle Electric Dryer...
When i run my GE Clothes Dryer, It has a high pitch squeak How can I fix this
remove the front panel inside there is what is called the top door bearing,its probably worn through the drum slides and into the plastic bearing creating this squeal part # WE3m26
Feb 10, 2013 | GE Dryers
Dryer sqeaks while it's running
This could be the result of a loose/worn belt, or worn drum roller bearings. Is it a constant squeal or a squeak......squeak.........squeak, basically in time with the RPM of the drum? If that is the case, get new drum bearings. If the former is the case, get a new belt.
May 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is squealing and have to run it twice to get my clothes dry
the squealing/squeaking noise is more then likely your drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
the drying twice is a venting issue:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Whirlpool LEW0050P Electric Dryer
The dryer squeaks - noise is coming from left hand front of dryer. I've take the cover off, there is a plastic piece that if I press toward the front of the dryer stops the squeak. The heavier the...
The squeak is actually the rear bearing WE3X75.
98fbf6b.jpegOddly enough although this might be your part you should use your model number to order the part. Different production runs I guess. Theis dude mounts in the rear
66ec823.jpgright in the center of the heater. This bearing gets real thin and when almost gone starts the squeal. You must remove the drum to get to the backside and replace that dude. I have a pictorial and more HERE.
Oct 12, 2010 | GE DBXR463GB Gas Dryer
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
My 11 year old electric Ge dryer squeaks when running.
WD-40. (Water Displacement test number 40)
Most likely just humidity and splashing water finally got to the parts and create a bit of rust, corrosion, and wear. Squeaking is nothing to worry about. If it starts to squeal then you have a problem.
Mar 14, 2010 | GE Dryers
Kenmore 700 6972 Dryer Logo
2,094 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
