Question about Quantum DLT-V4 DLT Tape Drive
We are having an issue with our backups. The system event log says there is an error 7 and lists the tape drive as having a bad block. However the quantum diagnostic tool shows the drive to be healthy. Any ideas?
Event ID-7 is a "Bad Block" on the Tape being using. By design, when a Bad Block is encounter, the Tape Drive "Seizes the Tape" and goes offline. It can sometimes be difficult to get the Tape Drive to release the Tape. Refer to the Users Manual for instrcutions on how to Reset the Tape Drive. Sometimes applying the Firmware Update willl reset the Tape Drive and Eject the Tape.
Do not assume the Tape is Bad, but do not re-use until tested. The Tape may be Bad, the Tape Drive may simply need Cleaning or the Tape Drive may be Worn or Damaged. If you are using 3rd Party Backup Software, such as Backup Exec or Yosemite, you wan want to check the Removable Storage Servcie to see if it is set to Manual or Automatic. Any Tape Devices would need to be first Deleted in the Library Section of Removable Storage, then Sop and Disable Removable Storage. Since Removable Storage is in effect NTBACKUP, this Service can interfere with the Operation of your Backup Software and generate "Bad Block" Errors.
To Test the Tape with your Quantum Tape Drive, use a tool called XTALK ( xTalk-6.4.1.1_Quantum_Setup.exe ) that is found on Quantums Website http://www.quantum.com/ServiceandSupport/Index.aspx
You may run a write_read_full Test on the Tape. Be sure to Clean the Tape Drive first. If it fails the Tape, try it with a 2nd Tape, If it fails again, suspect the Tape Drive.
OldCountry73436
Posted on Jan 07, 2011
Backup tape(RDX) getting ejected automatically after sometime while backup job is not running.
RDX tape drives, by HP (tandenberg)
did you reload all that HP software and drivers fresh?
did you try fresh tape.
i replace the tape drive, (new , used, NOS , from whom, ebay)
i bet the tape drive, logs errors, if you look,
the driver software will log that, and you can see why the tape
failed, my guess, damage to the tape, end to end.
try fresh new tape, NEW in a box, not used.
Oct 13, 2017 | HP Computers & Internet
Blue screen appears after loggin into windows 7 pro 32bit
try reboot in safe mode and try a system restore...r if u want u can go to the event viewer and try searching ur error log and see if u can find the problem yourself. most times its a bad driver r a newly install software r even update causing the problem r a virus... if u have a backup on hand just restore ur system.
Jul 01, 2011 | Computers & Internet
I was trying to backup my server while exchanging DLT tapes, the tape in use light stayed on and the serve would then alternate to four flashing lights and then back to flashing "Tape In Use...
Try the following action to resovle your issue:
1. Run the Drive Assessment Test in HP StorageWorks Library and Tape Tools.
CAUTION: Running the Drive Assessment Test overwrites the tape. If it is not possible to
overwrite the tape, run the logs-based Device Analysis Test instead.
2. Check the backup logs.
3. Verify that a supported configuration is being used.
4. Check for media damage:
o Incorrect label placement
o Broken, missing, or loose leader pin
o Damaged cartridge seam
o Usage in incorrect environment
5. Check for software issues:
a. Check the backup software.
b. Check that virus scanning software is not scheduled to run at the same time as the back-up.
6. Verify that a tape can be formatted.
Tape Error LED is flashing:
1. Reload the suspect tape. If the Tape Error LED stops flashing, the problem has cleared.
2. Load a new or known good tape. If the Tape Error LED stops flashing, the problem has cleared.
3. Reload the suspect tape. If the Tape Error LED flashes, discard the suspect media as faulty.
From my experience, most of the time it is a bad tape, using a new tape usually solves the problem. If after inserting a new tape and the problem exist, you may need to update your firmware/backup software.
Good Luck
C2Solutions
Jan 13, 2011 | HP Compaq ProLiant ML350 G3 Server
My problem is my computer is always reastart in working my opareting system is windows 7
This sounds like a hardware issue, you need to check your error logs and see what is happening. Hard drives sometimes manifest errors like this. The Windows error logs are listed under the EVENT viewer, press start and type event. What you are looking for are errors or critical errors. warnings and information is of little concern. If these logs do not show errors, of significance, hard drive is suspect, again, as failure precludes the error being written to the disk.
Dec 15, 2010 | Computers & Internet
Western Digital 1TB elements freezing windows media player
run a scan on the drive and update windows media player it is buggy, also do a defrag of the drive as well.
Aug 18, 2009 | Western Digital Elements powered by WD 320...
Seagate freeagentGo does not work with windows server 2003
Symptoms The problem I encountered after connecting the drive to the eSATA card was the following error in the Windows System event log:
Source: Disk
Event ID: 7
Description: The device, DeviceHarddisk2, has a bad block.
At first I thought this indicated a bad disk. But eventually I saw apattern: the bad block error only occurred if the drive had enteredits "sleep" state, i.e. had spun down. By default, this happens after15 minutes. If I accessed the drive in Windows explorer after it hadspun down, in the few seconds that it took it to spin back up, Windowswould get impatient and report a bad block error. Note that the "sleep"mode I'm referring to is an internal feature of the Seagate drive--itis not under the control of Windows Power Options in the Control Panel.
If I attached the Seagate drive via a USB cable, let it spin down, and then accessed it, I did not get a bad block error.
Another symptom, one that I did not at first associate with theFreeAgent disk, was the following message in the Application event log:
Source: VSS
Event ID: 12289
Description: Volume ShadowCopy Service error: Unexpected errorDeviceIoControl(\?Volume{ba849e07-88fb-11d9-9c6f-806d6172696f} -0000017C,0x0053c020,00039B48,0,00038B40,4096,[0]). hr = 0x80070017.
This error occurred when I started an ntbackup job. Apparentlyduring Volume Shadow Services initialization, it couldn't immediatelyaccess to the Seagate drive and so logged this error. A bad block errorwas also logged at exactly the same time.
CauseMy speculation is that Windows knows that USB drives may spin down, andit will wait for them to become accessible. However, because an eSATAdrive runs as a BIOS-attached drive (similar to a SCSI drive), Windowstreats it as an internal drive and expects it to be "on" at all times.
SolutionThe solution is to attach the drive to a Windows XP or Vista machine,install the FreeAgent Tools software, go to Utilities, and set theDrive Sleep Interval to Never. Then move the drive back to the server.The Sleep Interval setting is maintained even though the drive ispowered down when moving it to another machine. Once I did this, boththe bad block and the VSS errors stopped.
ConclusionIt's obviously a pain to have to install a 142MB software package justto change the Sleep Interval, but Seagate Support said there is noother way. Too bad they don't make a simple command-line utility forupdating the drive settings. (The software has lots of slickbackup/restore features, integration with Internet drive access,etc.--all kinds of things that I don't need in this environment.) Itried installing the FreeAgent software under Windows Server 2003, butthe installation failed with a message that it only runs under Windows2000, XP, or Vista. Hence the solution of temporarily installing thesoftware on a desktop machine.
I wonder if others have had similar problems with eSATA drives thatlike to go to sleep? Eventually Windows may need to add an option totreat eSATA drives like it treats USB drives. Considering that thisdrive is only used once a day during backups, it would be nice if sleepmode worked without causing errors. In the meantime, I'll hope thatkeeping the drive out of sleep mode resolves the "bad block" errors.
copied from : http://blogs.mcbsys.com/mark/post/Seagate-FreeAgent-Pro-eSATA-and-Bad-Block-Errors.aspx
Jan 06, 2009 | Computers & Internet
Blue screen error 0x00000024 dont have recovery disk
This Stop message, also known as Stop 0x24, indicates that a problem occurred within Ntfs.sys (the driver file that allows the system to read and write to NTFS drives).
Resolving the ProblemDisk Corruption. Corruption in the NTFS file system or bad blocks (sectors) on the hard disk can induce this error. Corrupted SCSI and EIDE drivers can also adversely affect the systems ability to read and write to disk, thus causing the error.
Check Event Viewer for error messages from SCSI and FASTFAT (System Log) or Autochk (Application Log) that might help pinpoint the device or driver that is causing the error. Try disabling any virus scanners, backup programs, or disk defragmenter tools that continually monitor the system. You also need to run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Run Chkdsk /f /r to detect and resolve any file system structural corruption. You must restart the system before the disk scan begins on a system partition. If you cannot start the system due to the error, use the Recovery Console and run Chkdsk /r.
rate me if you think its fixya...
regards,
Dec 06, 2008 | Gateway MX6025 Notebook Computer...
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
SONY TSL-S9000L error message
Hi RIO,
I need a little more information to better assist you with your problem. What Operating System are you running and how old is this unit?
Is this the first time you are using this device?
Also look at the event viewer for info on the actual error, which could help to better explain what the problem might be.
--Roadhawk
Nov 24, 2007 | Sony TSL S9000L (TSL-S9000L) DAT Tape...
Quantum DLT-V4 DLT Tape Drive Logo
566 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
