Question about Siemens Washing Machines
My siemens XL 1600 washing machine keeps bleebing 10 to 20 minutes of cycle, have checked filter and water inlet and outlet as per manual but all are fine. Any ideas?
  • 549 Answers
If it is out of balance this can occur.
Try leveling and then make sure the load is not lop sided.
Posted on May 27, 2008
Dishwasher humming, check water light on, no progress
Sounds like the inlet solenoid is not working. It lets water in. It is operated by the control board. Either could be bad. You would need a schematic and a multimeter to check the solenoid. Dangerous voltages are present.
Jun 02, 2015 | Siemens Dishwashers
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
Lavalogic 1620 leak from rectangular hole at top of unit
is your inlet water pipe pointing straight down?i have read the instruction manual for this machine and it says to have the inlet water pipe turned 90 degrees to the left or right. is the rubber seal firmly in place? hope this helps..
Dec 04, 2013 | AEG Lavamat Lavalogic 1600 Front Load...
Hello, I have a Siemens 1600 WXL166AGB (1600 XL) washing machine. there is a humming while still washing and then it stops and beeps on drain, but not every time. have cleaned out filter, impeller turns,...
Sometimes the impeller can wear so that it is pulled to one side and jams intermittently. Try removing the pump and running it outside of the machine to see if you can catch it misbehaving. Or just replace the pump.
Sep 13, 2013 | Siemens WK61420GB Front Load Washer /...
The washing machine is taking longer time
You can check that pump filter which is behind the base plinth, also check that the water entering the machine is at a reasonable pressure. If the machine is taking a longer time to wash and both inlet and the outlet of water is ok, it is more than likely a wash side heater fault. Basically, you set, for example. a 40 degree cycle, the heater does not operate and the water never reaches the required temp, the machine ventually times out on the heat phase and then moves on to the rinses or aborts to the end of the cycle.
Nov 26, 2011 | Bosch Washing Machines
I have a LG direct drive wahing machine and its flashing IE cant find manual what does it mean please help!
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. Check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. If clogged, water will not flow through these filters into the washer. Disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg If this doesn't work then you will need to change the water inlet valve by removing the top panel.
Mar 15, 2011 | LG Washing Machines
Dishwasher runs about 3 hours
First check the inlet water flow into the machine. There is a strainer attached to this. If it is clogged water filling into the machine will be delayed!
Also check whether using the same wash program as you were doing earlier. There can not be any other fault aprt from this. i presume the wash quality is good.
Heance clean all the water inlet and outlet for free flow.
Jul 08, 2010 | Siemens 24 in. SE25A091 Hi-Line...
Cloths stink, towels not soft. Can I increase the amount of water used per cycle? How? thanks, jim maxwell
Make sure there are no leaks from the machine. Look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose and door rubber is completely clear of debris and soap scum build up and check that the filter is clean.
You can initially use a bathroom mould and bacteria cleaner to get rid of the immediate problem or wash using a bleach solution made up from 1 part household bleach to 10 parts water. Place this in an aerosol spray bottle and spray the affected area and leave for 10 mins then wipe away and rinse with clean water.
  1. To keep the machine clean of waste or mould build up and to keep any bad odours away
  2. Remove all items from the washer.
  3. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
  4. Close the washer door and dispenser drawer.
  5. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
  6. Press Start and allow cycle to complete.
  7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
  8. Repeat the cleaning procedure monthly
Also from your description it sounds as though you need to use a water softener (washing soda) or use slightly more deteregent and possibly more fabric conditioner inthe wash. Also washing performance can be increased by using slightly higer temperatures and / or a bilogical detergent.
Nov 09, 2009 | Maytag Neptune Washer
Bosch SHE45M Odor? What can I do
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean. Do this on a regular basis.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Add 1/4 cup (60 mL) of liquid chlorine bleach to tthe machine. DO NOT use more than 1/4 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C) if you have one or use a 60C wash. DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure as necessary.
Sep 30, 2009 | Bosch Dishwashers
Very damp smell
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
7. Repeat the cleaning procedure monthly
Sep 12, 2009 | Washing Machines
Washing Machines Logo
1,254 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
