HP LaserJet 2420 Printer Logo
Posted on Oct 04, 2010
I need Hppaufd0.sys to get HP LaserJet 4250 to work. I use windows XP, didn't know if that made a difference, I don't have disk and need to use this printer.
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Feb 13, 2008
SOURCE: hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Anonymous
  • Posted on May 13, 2008
SOURCE: Hp 1018 Driver for windows98
I need to windows 98 driver for hp laserjet 1018
Anonymous
  • 4 Answers
  • Posted on Jun 05, 2008
SOURCE: windows xp with not recongise HP Laserjet 6p when plugged into a usb port
When it shows the message new hardware found click on "start" then click on "printers and faxes"Select the option on right side 'add printer" or select from file menu "Add printer" click next if insert installing CD Disk which came with Printer written Divers then click next now computer will start looking for Printer's Driver
other Subjection is
when it shows new hardware found message click on that message Insert Divers CD which came with that Printers Select the option to install driver from CD
Another subjection is Install the CD which came with Printer
Actual you don't have to any thing Insert CD It will auto play and
start installing just read the caption and select the alternatives
Best Of luck
Anonymous
  • 564 Answers
  • Posted on Aug 19, 2008
SOURCE: HP Laserjet 4250 leaking Toner
time for a printer plumber no doubt...leaking toner is not a good sign..
Anonymous
  • 68 Answers
  • Posted on Oct 02, 2008
SOURCE: HP LASERJET 4250 DUPLEX ISSUE
only problem ive had with the earlier model not doing duplex was a sheet of paper in the duplexer bin . This is hard to find but if you pull out the paper tray and look in the space where the tray goes up above theres a lever which you can push and it releases the hidden duplex bin which stores the paper at half way through the double pass and if there is any paper in there then the printer will not duplex.
2helpful
How to remove DIMM from the printer hp laserjet 4250
Open right cover, open formatter door, you can easily find out ram located down side of the fomatter, but don't handle RAM/DIMM with bare hands..
tip
What is the Windows XP Administrator Password?
<p>Windows XP, the most popular versions of Windows, was widely installed by PC users. Do you remember after you installing your first copy of Windows XP, how long did it require you to realize that you didn't know the administrator password? I vaguely remembered that it was about a week before I needed to make some changes in the file system. It suddenly came to me to be logged on as an administrator, but I do not know the password of the administrator! <br /> <p> <br /> <p><img src="windows-xp-administrator-password.jpg" /> <p><br /> Luckily, Windows XP (both Home and Professional versions) have a "hidden" administrator account which is autogenerate when install. This account usually doesn't show up on the logon screen and most people are totally unaware of its existence. Usually it is ok because we didn't need to user this account very often, only when we don't know the administrator password, need access to the Windows XP recovery console or boot into Windows XP safe mode, the default <b>Windows XP administrator password</b> would come in handy.<br /> <p><br /> What is the Default Administrator Password in Windows XP?</b><br /> <p><br /> Knowing the default password of Windows XP administrator account would be very useful.<br /> <ol> <li>Try to leave the password blank. Simply press Enter without typing anything.</li></ol> <p>The default Windows XP Administrator password is defined to blank during the initial Windows XP installation process.<br /> <ol> <li> Enter the password for your account. It often depend on how Windows XP has been installed on your computer and what part of XP is asking for an admin password, the main user account will also be configured with administrator privilege.</li></ol> <p><br /> I Forgot my Windows XP Administrator Password!</b><br /> <p><br /> Windows XP User Accounts applet in the Control Panel functions is to create a password reset disk wizard. Using this wizard, a floppy disk or USB flash drive can be used to create a specific password reset disk for specific user account on a specific Windows XP computer. The password reset disk can only be used with the computer it was created on and it can also be reused to reset the account's password multiple times. However, you need to know the password of the account you want to create the reset disk for, and you must create the reset disk before you forget the administrator password <br /> Here is how to <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">reset XP administrator password</a> with the XP password reset disk:<br /> <ol> <li>Insert the XP password reset disk to the computer</li> <li>Click the Use your password reset disk item on the XP logon screen to start the Password Reset Wizard. Click the Next button</li> <li>Follow the instructions to create a new password. </li> <li>Logon with the new password.</li></ol> <p><br /> I Didn't Create a Password Reset Disk!</b><br /> <p><br /> OK, if you <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">forgot Windows XP administrator password</a> and don't have a password rest disk, you won't be able to create a password reset disk anymore. Instead, there are several things you can try to get access to your windows. <b>SmartKey Windows Password Recovery</b> is your ticket. This password recovery tool not only works on Windows XP, but also on all releases of Windows NT/2000/Vista/ 7 and Windows Server 2003/2008. It works by booting from a CD/DVD or USB flash drive and reset the <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">forgotten Windows XP administrator password</a>.<br /> <p><br /> <b>NOTE: </b>If you change the administrator password on a Windows XP or Windows Vista system with the Encrypted File System (EFS), all of the encrypted files will become inaccessible. The password for the Administrator account is used to create the EFS encryption key. Changing the Administrator account back to using the original password should restore access to the encrypted files, but I have never tried it.<br /> <p> <br /> <p>If you only need to blank the <b>Windows XP Administrator password</b>, here are the basic steps:<br /> <ol> <li> Download and install SmartKey Windows Password Recovery software.</li> <li> Burn the software to CD/DVD or USB flash drive. </li> <li> Insert newly created CD/DVD and reboot your computer from the CD/DVD or USB flash drive </li> <li> Reset the forgotten Windows XP password, remove the CD/DVD or USB flash drive and then reboot the computer</li></ol> <p>Having the capability to reset <a href="http://recoverlostpassword.com/products/windowspasswordrecoery.html">forgotten XP administrator passwords</a> and regain access to a locked computer can be a great time saver, but should only be tried by an IT professional. you may probably make things worse rather than better if you use sophisticated system or manipulation tools<br /> <p><br /> <p>Article Source:<a href="http://recoverlostpassword.com/article/windows-xp-administrator-password.html">http://recoverlostpassword.com/article/windows-xp-administrator-password.html</a><br />
on Apr 15, 2011 • Computers & Internet
I have purchased a recycled HP laserjet 2420n with no CD. I did the plug and play and my PC recognises that it is there but then asks me for the HPPaufd0.sys file. I have searched for it. I have gone...
You will need to download the correct driver for your OS from this HP website. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=412129&taskId=135&prodTypeId=18972&prodSeriesId=416419&lang=en&cc=us
Install the driver and plug the printer back in. It will now find the new driver and will have all the support files as well.
If you continue to have issues, temporarily disable your viruses scanner while you install the driver. The drivers from HP's website contain no viruses so your scanner may give a false positive if it tries to remove any files while installing.
Regards, Chris
1helpful
Where can i get a laserjet 4 (c2001a) installation cd? It works with one computer (the printer) but not any others. I tryed to copy the driver from one computer to another and that screwed up the one that...
The laserjet 4 is a standard driver already included in windows xp. You shouldn't actually need to download anything. When installing the printer you should be able to choose HP from the list and then navigate to HP Laserjet 4 in the list. When you do this it may need the windows disk if you don't have the i386 directory copied to your PC. If that's the case then just pop in the windows CD and point it to "CD-Rom"\i386 and it should find the drivers on its on.
HP LaserJet 4250 PCL 6 - Cannot get Duplex disabled
Try turning Duplex off at the printer. See if that does what you want.
Repair on Hp laserjet 4250. Printing but smearing black ink on paper
the fuser roller needs to be checked/ replaced. this is in the fuser unit which is availale in the maintenace kit from hp. all instructions in the manuals and on hp website
Print Job enter's queue, but doesn't actually print.
hi thanks for using fixya!
Do you have 32bit or 64bit system?
Using XP sp2, excel 2000 and HP 4250 printer. Any
The print settings can be different for different programs. Open Excel and in the File menu, choose Page Setup. Click on Options, and towards the bottom is a setting that says Copies. Change this to "1" and hit OK, and you should be fine.
Hope that helps!
2answers
Hp 4250 paper jam erro
2answers
HP laserjet 4250 evelope smudge
What kind of trouble are you having?
ie.
is it jamming is it making noises???
4250 n ,nt dtn?
k24674
Grand Canyon Tech
Grand Canyon Tech
