Question about Buck Cuddeback Expert Game Camera
I have a cuddeback capture. When I turn it on it takes a picture every 30 seconds or 1 minute or as often as I have it set. There doesn't have to be any motion. I have replaced the battery's several times and it doesn't help. Even in test mode the red light blinks constantly. I don't suppose this is a simple fix. Thanks Ted Mlnarik
3 Suggested Answers
guru_fixya
  • 944 Answers
SOURCE: Cuddeback 4300 takes picture every minute.Laying
Sounds like the pyros is the problem.So it will cost around 50$ maximum.Shipping charge included.
Try to repair it local repair shop near you area.
Thank you for using fixya have a nice day:-)
Posted on Feb 24, 2011
SOURCE: just got a brand new NEVER OPENED '06' cuddeback
Hi gtepwisc. I just bought a Expert also and the problem was similar. My package was opened and I paid $150 at The Farm. They told me not to worry, anything wrong with it and Cudde would take care me, as it should be warrantied for a year. YEAH RIGHT!!
It done the same as yours, it took forever to go through the startup on the lcd screen even without a card. Then I soon found out why it was a returned item. The card would not go in all the way. I looked up in the card slot and the wires that go inside all those tiny holes in the card were all bent to hell. Some were making contact with other wires. So check that in yours right away. I thought, GREAT! I don't really want to return it back to FF as it really is a nice camera so I called up Cuddeback. They said it is no longer under warranty because they discontinued that model and also because the card reader is damaged, even though I didn't damage it! Then they told me they would exchange it for their Cheapo Capture model for only $100 plus my camera or repair it for $150. I told them neither of those options are acceptable as this camera should be under warranty. If that is how you treat your customers I will never buy another Cuddeback and let others know.
Then I thought of a good TV Repairman in my area who is good at fixing many electronic products. He looked at it and said it doesn't look promising but would give it his best. He not only straightened out all those prongs so that card goes in nice and smooth. He soldered a couple wires to the positive and negative way inside the camera so I can hook it up to my 6 volt tractor battery and not have to deal with D-Cell batteries in that terrible setup they have for that model. That is real sweet. My tractor battery will last a year before I have to recharge it. Anyhow, that took care of the problem of the slow forever startup and the card has went in perfectly over 20 times so far. Granted, I take my time putting it in and line it up gently before I push it in. That repairman only charged me $40 for all his work. That shows there are still some good, honest people out there. The camera takes some of the nicest colorful pictures I have ever seen and the trigger time is just unreal. Right now I wouldn't trade that camera for any newer camera out there but I had to go through hell. I hope I helped you and gave you some ideas to try. Also, I use a rubber bungee ******** the tree and just put old broken pieces of tree branches behind the top and bottom of the camera to act as shims so it don't wobble all over and stays in place. Good Luck
Posted on May 06, 2011
Can anyone tell me how to set my camera up to capture shots of the Aurora Boreleas?
I don't think there is one correct setting.
There are several ways to find out what is best for your camera. Some (seamy) professional camera's can shoot to very high ISO settings, so they can take pictures in shorter times.
You should start with a good tripod, because your camera will need seconds in stead of tenths or hundreds of a second.
At home, set up your tripod with camera on a bright night. Try to make pictures of the sky with shutter times like 1, 10 and 30 seconds. Look on what picture you have a good contrast between the stars and the background. That should be the starting point when shooting the aurora. Get used to long shutter times and how the camera reacts, because saving a picture that took 10 seconds to take, will take another 10 seconds to save.
You also could look up some pictures from the Aurora Borealis on Dpreview or Flickr and see what the settings of the camera's were. Would be great if you found pictures made with the Canon Powershot SD600, but if nit, you still can see what you can expect .
Nov 08, 2013 | Canon PowerShot SD600 Digital Camera
N73 nokia, i have problem in take of the image capturing , in the image capturing mode doesn't key accept for image capture but it has work for video capturing. so plz help me what i do?
Generally the image capturing button should press 1-3 secs to get a picture.If it doesn't works there might be some hardware problem.But first try to Restore the phone by typing *#7780# and capture.If the problem still persist contact mobile repairing shop. The camera switch may damage .Or at least clean the pcb if you can remove the cover ..Thanks for visiting fixya
Mar 18, 2012 | Nokia N73 Cellular Phone
Samsung LN46A650 that cycles on and off with no picture. The red light flashes in the lower right hand corner. Still no picture. Have to unplug power supply to turn it off.
Turn it on and let it run for about 30 seconds. If it still doesn't work... unplug it, wait 15 minutes, plug it back in, then try again. If that doesn't work, you might want to contact Samsung to see if it needs repaired or replaced.
May 20, 2011 | Televison & Video
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
On the easyshare m575 what does the self timer/burst feature do?
Self-timer
(10-second delay) it will have a 10 on it
Time to get yourself into the picture. Place camera on a tripod or flat surface.
Self-timer
(2-second delay) it will have a 2 on it
Allows for a steady, auto-shutter release on a tripod.
Self-timer
(2 pictures) it has a 2X on it
Capture 2 shots (one picture taken after 10 seconds and another picture taken 8 seconds later).
First Burst
Flash forced off.it has like 2 folders in front of the camera
Camera takes up to 8 pictures (2 per second) while the Shutter button is held. The first 8 are saved. (Capture an expected event e.g., baseball swing)
Last Burst
Flash forced off. it has 2 folders behind the camera
Camera takes up to 30 pictures (2 per second up to 15 seconds) while the Shutter button is held. When the shutter button is released, only the last 8 pictures are saved. (Capture an event when the precise timing is uncertain e.g., a child blowing out birthday candles.)
Mar 03, 2011 | Kodak Cameras
Just got a brand new NEVER OPENED '06' cuddeback Expert model C3300 from a store that never sold it. I put in new batteries and a 256MB CF card and went thru the setup..put in my name a passcode..set the...
Feb 26, 2011 | Buck Cuddeback Expert Game Camera
Very slow to turn on and has small light spots all over screen
The first thing to look for are swollen capacitors on the power board.replace them if so.
Sep 11, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Pics out of focus
Sounds like "Camera Shake"
With Digital photography, any motion of the camera will tend to blur the photos. You'll see double edges in some photos, and plain fussy pictures in others.
The sharpest photos come from cameras sitting on stationary objects while the picture is taken.
Depending on how advanced your camera is, there are a couple of settings you can toy with.
One is the ISO setting which mimics the "Film Speed" exposure rating of camera film measured in as ISO100, ISO 200, ISO 300, ISO 400.
The Ratings are a balance between Fast action light capture, and slow higher resolution detail light capture.
ISO100 will make a cyclist passing by look like they're standing still.
ISO400 will make a cyclist passing by look like a blur passing by.
ISO100 will have larger dots of colors on the picture, (Low Resolution)
ISO400 will have tiny dots of colors on the picture, (High Resolution)
So, ISO setting is a matter of getting the best picture without the blur; get as close to ISO 100 as you can.
The other setting is Shutter Speed.
Some cameras will allow you to slow the shutter speed down to help get clearer pictures in dark environments, like places with high ceiling lights, or outside after sunset.
Again you want the fastest option available, here the balance is the same as the ISO, bright clear picture versus dark blurry picture, so you want the shortest shutter speed possible.
This is measured in fractions of a second, and often only the denominator (lower half) is mentioned, like this:
1/8 of a second is called 8 or (125 milisecond)
1/4 of a second is called 4 or (250 miliseconds)
1/2 of a second is called 2 or (500 miliseconds)
1 whole second is called 1 or (1 for one second)
On digital cameras it often simply mentioned as the fraction in a menu called shutter speed. The default is often the fastest capable speed.
Browse the menu options for ISO and Shutter speed to see what modifications you can make.
Remember it's about capturing the light, so bright sunny days are easy highest speed settings, but shady or indoor environments will take practice and fine tuning.
Also, make use of the timer delay option and set the camera on a stationary object to capture the clearest sharpest images.
Have Fun.
Jul 28, 2009 | Casio Cameras
FZ15 Problem should i buy new or get fixed?
Yime for a new one - the price of a repair will be almost as much
Oct 14, 2007 | Panasonic Lumix DMC-FZ15 Digital Camera
Buck Cuddeback Expert Game Camera Logo
127 people viewed this question
Top Buck Cameras Experts
Are you a Buck Camera Expert? Answer questions, earn points and help others
