click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
also
When you boot up to the log in screen type in administrator as user to log in if you cant log in during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you can change the password there
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
or
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
or
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive)
there are a number of things that you can do to remove your password another option would be to remove your cmos battery Hope this helps
