Question about Saeco Magic De Luxe Espresso Machine
Replacement Parts My machine is 15 months old and has produced 5700 cups of perfect expresso. My brew group is growning like it need lubrication and the "O" and I would like to replace the O ring The panarello need a need O ring and the two rubber seals that hold unit on the steam pipe. Right now the panarello shots off the end. This makes steaming milk a bit of a challenge. Also I would think there are hoses in the the unit that need replacing, are these availbile for purchase. Thank You Harry Derra harryd1951@gmail.com
    Sergeant:
  • Saeco Expert
  • 223 Answers
You can purchase the brew group lubrication on our website. The orings for the panarello are not available and you would have to purchase the whole thing. You can also find panarello's on our website. You may not find the exact one, but most of them are the same size.
Saeco parts and Cleaning supplies.
www.CeriniCoffee.com
Posted on May 29, 2008
What do I need to do when error 8 is displayed on turning on machine?
Jura does not allow access to internal parts for cleaning. Brew group is the dirtiest part as it deals with complicated movements to make coffee.
Error 8 means the brew group is not returning to start position after it completes entire cycle to make coffee.
Jura recommends to remove drip tray. Using a thin cloth, insert the hand all the way under the machine. You will feel access to the bottom of the brew group. Wipe clean the bottom of brew group as best as you can. There will be lot of coffee powder (wet & dry) that is partially responsible to prevent brew group return to start position.
A better method is to open the machine using special key. Clean & lubricate the brew group. every two months. This will prevent Fungus and Bacteria growth. .
Instruction videos are posted on You tube channel "Parts Guru USA"
Use the link below to order the special key. Services Unlimited Inc Parts Guru Since 1988 Services Unlimited Inc Parts Guru Since 1988
Mar 20, 2016 | Jura Capresso Impressa S9 Coffee...
Why are the used grinding pads on my saeco odeo giro very loose and watery
I can personally confirm this fix from another similar question works: "I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough, it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount." My manual didn't have very good info about lubricating the brew group, so I referred to some Youtube videos demonstrating the methods. A sourced a 3rd party food safe lubricant from Amazon which I applied with Q-tips, but in retrospect they also sell Saeco "maintenance kits" which would have been cheaper & easier to apply, plus it includes a new O-ring.
Jun 01, 2014 | Saeco Odea-Giro Espresso Machine
Delonghi BCO330T won't heat or brew on coffee or expresso side. Burner won't heat but power is getting to the machine. 17 months old, out of warranty.
Delonghi BCO330T, this is my third one and it has the same failure. It is a know problem and the answer is they don't care
Apr 06, 2014 | De'Longhi BCO330T Combination Steam...
Do you know where can i find the rubber gasket that goes around the brew head of my Cuisinart EM 100 espresso machine ?
It sounds to me that your group seal is bad. Since this machine is a 15-Bar unit, it puts out quite a bit of pressure causing water to leak out around the portafilter when making espresso if your seal is old or damaged. The pressure doesn't build up as much when you are running just water through the machine - hence the reason why the machine works ok without grounds. I sell a LOT of parts and accessories for various manufacturers of espresso machines. This particular seal is extremely difficult to locate fom Cuisinart, but is rather easy to replace. Through extensive testing, I have located a replacement gasket produced by another major manufacturer that fits the Cuisinart EM-100 & EM-200 machines perfectly. I sell them for $10.99 each (or two for $19.99) which includes shipping in the continental US and I accept Paypal. If you would like to contact me via email (cowboy_romeo@yahoo.com), I will be happy to help you out.
Mar 20, 2012 | Cuisinart EM100 Stainless Steel Espresso...
My machine wont give me much water into the brewgroup tried another brewgroup and it is the same . Iyt takes about a minute to put thru one shot of coffee and we only get about 10mm of expresso in the cup...
Hi
If you push the scoop but don't put any coffee in the brew group, what happens? If it brews right (water comes out), then I would suspect that your coffee is too fine. Push the lever below the grinder on the right to the back (#7) and then try to brew again. Don't let it go all the way. Push the coffee button as soon as it starts to brew. Do this 3 times. The 4th time let it go and see if it will brew. If it doesn't I would need more information.
Aug 10, 2011 | Saeco Royal Cappuccino Espresso Machine
Cannot release the brew group for, saeco
Group is stuck in mid cycle due to some obstruction. You will need to have it serviced. Though it's possible to jiggle and pull it out. The machine will not likely reset itself, preventing you from re-inserting the group. Still requires a service to manually remove obstruction and reset it.
Feb 08, 2010 | Saeco Odea Go
Hello. I have had my Incanto Sirius S-Series for
check your brew valve,maybe is plugged or leaking in tray.
Sep 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Odea giro plus gear that drives the brew group has broken 3 times
First, you're going to need to get the brew group out. Check this out to get the brew group out. You need to remove a screw and pull unless you're really crafty.
This video will help.
After that:
a) Yes, lubing will help.
b) Replace the o-ring on the piston in the brew group (it should be orange). It gets old and gummy creating resistance.
c) Reinforce the weak plastic that gets over-torqued.
I own three of these units, one from 2007 (made in Italy, never broke, has tens of thousands of brews) and two newer units (made in Eastern Europe, fewer brews, both broke). I can distinguish the newer ones because they have a "sleep mode". They really overtorque the gear.
I tried repairing with just glue and that lasted (surprisingly) several months. I tried again by using a thick paperclip as a drill bit and that lasted 7 months.
Now with the holes piloted, I drilled a little wider and put in heavier metal from a heavy-duty binder clip. Cheap and very strong! Let's see how long this lasts.
See before and after pictures. This metal won't bend!
Mar 01, 2009 | Saeco Odea Giro Plus Coffee Maker
Alternatively slow brew and water under drip tray
when you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Jan 09, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
289 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
