I have a te flashing on my LG Direct Drive WM14316fd
Washer only runs for a little while then flashes te
TE in an lg washer is thermistor fault. Can sometimes just clean the probe end off and of course check the wiring connections. It is located at the rear bottom of drum, in a black rubber grommet. Carefully pull out clean and try again otherwise replace.
Sep 23, 2013 | Washing Machines
LG wm2487hrm Washer not draining water. tE flashing. I drained water out of front and ran 2nd cycle same issue.
tE is a thermister error. It is a temperature sensor at the bottom front of the washer. tE can also be caused by a heater error. Some models have a seperate thermister, some incorporate it with the heater. It is very difficult to replace without taking the front off the machine.
Jan 25, 2011 | LG WM2487H Front Load Washer
I have an lg direct drive 9kg washing machine and the water does not empty from the drum it flashes 03
03 error means drain pump is blocked or broken check the filter first before having someone out.
Jan 10, 2011 | LG Washing Machines
Mi computadora no lee el cd
Bueno si el cd-rom no te esta reconociendo ningun CD te recomiendo que reenplaces el CD-rom por uno nuevo o mejor aun reeplazalo con un DVD rom y si tu maquina tiene memoria suficiente hasta podras ver peliculas. Verifica que cuando adquieras el dvdrom(si decides hacerlo) que te traiga un programa para dvd's.
Suerte
Dec 15, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When i press eject button cd drive is not
Sounds like the belt inside is broken or came off. Does te drive still sound like it is opening but does nothing? Also try using a small paper clip and push it into the small hole on te front of the CD-ROM that will at least open the drive manually and possible fix the problem if the device is stuck.
Apr 20, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
I want get data in Flash Disk TE-2200 Casio
try to perform the instructions again. You've possibly missed something.
Aug 27, 2009 | Casio Parts Cash Register PC Desktop
My system didn't regonize the flash drive
If it in't detecting the flash drive.....Then the driver must have been corrupted....so just uninstall unknown device....and try to connect te flash drive
Mar 15, 2009 | Acer Aspire T120 PC Desktop
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
