Question about Garmin nuvi 750 GPS Receiver
Friend says there was a battery recall on the Nuvi 750. Where is the information located on your web site?
    Problem Solver:
  • 7 Answers
You can check to see if your device was included here:
https://my.garmin.com/rma/recallLanding.faces
Posted on Oct 25, 2010
Nuvi 750 Car charger connection is intermittent.Either the Car charger or the Nuvi 750 connection is intermittent. The device will display a warning that it is using the battery - 27 seconds to turn o
It is very rare that it would be a problem with the Nuvi 750 GPS itself. This is because there are stationary gold pads on the bottom of the 750. No moving parts to wear out. We have seen problems with a bad plug on the charger that plugs into the cradle and the receptacle on the cradle can go bad as well. I would suspect more toward the cradle as we have seen the receptacles break away from the printed circuit board that is inside of the cradle. Best way to troubleshoot is to find a friend who has a duplicate charger and cradle and swap each piece, one at a time and see which resolves the problem... either the cradle is bad or the charger plug is bad. If you want us to test your unit, cradle and charger, let us know. Good luck! :) More info on charger issues here:
http://www.sharc.net/gps_charger_repair.htm
Apr 21, 2013 | Garmin nuvi 750 GPS Receiver
I have had my Garmin for four years. Recently it has started shutting off when I'm driving with the set plugged into the adapter outlet. If I press the power switch, it will reboot, but then after a...
Garmin is voluntarily recalling certain nuvi devices that contain a specific battery that was manufactured by a third-party supplier within a limited date code range.
Garmin has identified potential overheating issues with the use of these batteries in certain nuvi devices with a specific printed circuit board (PCB) design. Additional information about the nuvi battery PCB recall can be found in Service Alert Number: 1035.
The models that may be impacted by the nuvi battery PCB recall are the 200W, 250W, 260W, 7xx and 7xxT (where xx is a two-digit number). To determine if your unit is affected, please visit www.garmin.com/nuvibatterypcbrecall and enter your nuvi's serial number. If your unit has the specific PCB design and contains a battery from the specific date range, you will be given instructions on how to return your nuvi for a battery replacement at no charge.
You should not attempt to remove or service the battery on your own; all battery replacements must be serviced through Garmin's authorized service provider.
If you do not have web access, you may contact Garmin through one of the phone numbers below:
  • In the United States and Canada, call (866) 957-1981
  • In North America and South America outside the U.S. or Canada call (913) 397-8200
  • In Europe, Middle East, and Africa, call +44 870 850 1242 or 0808 238 0000
  • In Asia, call 886/2.2642.9199
  • In Australia, call 1800 113 738; and in New Zealand call 0800 427 652
Repair time will vary based upon location. U.S. customers, please allow 10-16 business days to receive your repaired or replacement device. Canadian customers, due to increased shipping and customs clearance times, please allow 20-30 business days to receive your repaired or replacement device.
Garmin sincerely regrets the inconvenience that this recall has caused and is making every effort to cooperate with customers, dealers, and regulatory agencies worldwide to ensure all parties are assisted according to national regulatory standards
May 24, 2011 | Garmin Nuvi 660 GPS Receiver
I just received my neww 1450LM Garmin Nuvi GPS today and it push the on/off power switch and it does not come on. so, I started my car and plugged it in and it still does not come on. Please tell me why it...
May 24, 2011 | Garmin Nuvi 1450LMT
I moved in a new state and forgot my garmin nuvi 750 pin code so how should i open it
you havent got a chance in hell, the only way to unlock it is to go back to your secret location
, where you set the pin in the first place. Either mail it to a friend or drive there, no other choice
Apr 14, 2011 | Garmin nuvi 750 GPS Receiver
Nuvi 750 battery will not hold a charge. Unit works fine if plugged into the auto power. What might the problem be? What is the estimated cost of repair.
Sounds like you just have a dead/bad battery.
You can check to see if your device was included in a recent battery-related recall here:
If your unit is not included in the recall and you are (or a friend is) handy, you can buy a replacement on the net and replace it yourself for around $25 (US Dollars):
http://vimeo.com/8387716
(There are other sources for the battery, I do know if the linked company is trustworthy.)
I'm not sure what Garmin charges for this type of service?
Oct 13, 2010 | Garmin nuvi 750 GPS Receiver
Low battery display comes on when it is turned on then it shuts off its self
If this occurs when running on battery power, then it sounds like you just have a dead/bad battery.
If your GPS works fine when connected to a power source, then leave your GPS plugged in to a power source over-night, and if you still have this problem...
Oct 11, 2010 | Garmin nuvi 750 GPS Receiver
We are back in Tucson but while in Ohio we heard there was a problem with the Garmin. We have the nuvi 750. Can you tell us if ours was one of them and what we should do. Carole
Oct 08, 2010 | Garmin nuvi 750 GPS Receiver
Hello everyone. I bought garmin nuvi 750 GPS six months ago. I use it travelling all over and it works pretty good. But I dont know how could i find alternate route for same destination. For eg. I want to...
What you're looking for is called "Via Points" as your friend correctly suggested. From the Garmin Nuvi 750 web based information:
nüvi 750 includes advanced navigational features to take the worry out of traveling. With route planning you can save 10 routes, specify via points and preview simulated turns on the 750's wide screen. In addition, nüvi 750 automatically sorts multiple destinations to provide an efficient route for errands, deliveries or sales calls.
"Alternate routes" are those routes that are created when the nuvi is used with a traffic receiver (FM or MSDN). This allows for a new route to be created with the traffic data so that routes suffering congestion, etc. are avoided. Some people also refer to the routes created when a turn is missed (the GPS indicates "Recalculating") as an "alternate route" but it is not.
Jun 17, 2010 | Garmin nuvi 750 GPS Receiver
The battery wont take a charge my computer is saying plugged in not charging
Check the manufacturer's web-site: http://www.compaq.com
to see if this battery is faulty, and if the manufacturer has issued a "recall".
Otherwise, unless you find a friend with the identical notebook, and can try your battery in the other computer, it's time to replace the battery, either by searching on http://www.eBay.com or by accessing the manufacturer's web-site, in order to get a "genuine" replacement battery.
Nov 23, 2009 | HP Compaq Evo n610c Notebook
Garmin nuvi 750 GPS Receiver Logo
44 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
