Question about Maytag SDE2606 Electric Dryer
Squeaky elec. dryer
Chirping noise at start of cycle after 5-8 min. noise goes away
  • Anonymous Jan 12, 2009
    squeaky dryer when loaded . it stops after a few minutes into the cycle.
  • 525 Answers
This could be attributal to a rear drum roller lacking proper lubrication, or having been overheated. Also, a dry idler pulley bearing could cause this chirping. Don't allow this problem to continue without investigating the cause.
Posted on May 27, 2008
Tinkering noise
Open the hood and listen, it may be a drive belt.
Mar 25, 2014 | 2014 Subaru Outback
Makes a chirping sound when the car is initially started
Have you checked the engine bay for a bird's nest ? LOL
Seriously now, I think it is one or more of your drive belts, just when starting to turn all your engine bits. Have those tightened or replaced as needed and you should be OK.
May 21, 2013 | 1997 Toyota Camry
My dryer makes a squeaky sound during adrying
the front guides around the drum or the bearing at the back may be failing partially or bearings in the motor may have started to noise,there is also the chance that the belt idle pulleys have started to wear,more than lightly it is the belt idle pulleys that have dried up or the bushings have started to wear
Jun 30, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Neptune MD55 elec dryer chirping noise
I would think it might be the "board" but I once went on a call for the same chirp on an oven...ended up being the smoke detector was low on battery..it cost them $$ for me to find that simple thing.
Oct 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Very noisey gas dryer hotpoint nvlr333gt
it sounds like the back bearing or the iderly pully does it do it with a load and with out or it could be the the front pads i wish you luck if you give me the model number i might be able to send you the break dowmn of your dryer
stewsappliance@rogers.com
rate this advise thank you
Feb 05, 2009 | Kenmore 63012 Electric Dryer
Loud squeaky Noise
this is not 100% diagnosis as can't listen to noise but fault may be bearing lip seal disintegrating which is a serious fault and if im right then bearing will shortly go as well. reason it is noisy during start is that seal is dry and gets wet when full of water
Apr 18, 2007 | LG WM-2277HW Front Load Washer
Maytag SDE2606 Electric Dryer Logo
296 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
