Question about Kodak V803 Digital Camera
The lens will not retract and the camera will not power on except for a second when it will seem to start up when I turn it on. We bought a new battery, and tried it out at the store, but it did nothing so we returned it
    Brigadier General:
  • 3,006 Answers
Your camera most likely has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 04, 2010
Kodak m522 turns off with lens extended
Here are some troubleshooting steps that you can try:
Dec 09, 2012 | Kodak M522 Digital Camera
Lens won't retract
According to Sony, storing the camera lens-down in a warm area for an extended period (a week) can help re-lubricate the retractor drive in cases like this.
This camera seems to have a predisposition to lens retraction problems. Try some gentle nudging, Even a small piece of debris can jam the mechanism, so it might just need a little push or pull.
Apr 16, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
When camera turned on it says lens error and then shut down
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
My camera was stuck with an open lens and saying ?lens error, restart camera.? I banged it against my hand a few times, the lens retracted and all seems to work as it should now. Thanks for the post!
Dec 18, 2010 | Nikon Coolpix S3000 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Turn camera on, lens goes in and out then camera shuts off
You may try resetting the Camera to the original factory settings.
If the issue persists then service will be required.
Aug 27, 2009 | Panasonic Lumix® DMC-FS3 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
I733 POARIOD PICK CAMERA.
I just dropped mine last night and the lens got in this funny bent position, so I popped it back to where its suppose to be. Now the camera turns on and off without the low battery signal but the lens doesn't retract or do anything by itself anymore. I can hear the little motor running that retracts the lens, but the lens itself doesn't actually move when I hear the little noises. So now, I have a wonderful camera with the lens stuck out. I should state that I have the i631. It's just like the i733 but one megapixel smaller. I've the receipt from the retailer that I bought it from so I'm hoping polaroid will at least look at it. I bought it back in June! It's only 4 to 5 months old!
I'm not sure if this will work for all of you, but try plugging it into your computer. When I had this issue for no apparent reason, plugging it into my computer seemed to awaken my camera out of the protective sleep mode that it was in. Sadly, it's not working for me this time.:-(
Mar 11, 2008 | Polaroid i733LP Digital Camera
Bonnie
I was getting the Lens Error message on my A730, even though my lens seemed to be working fine. I'd had the camera in my pocket, and apparently it tried to open but jammed. But it seemed to be OK except for the cursed Lens Error message when I'd power it on. The way I found to fix it is press and hold the "func/OK" button on the back, then turn the camera on. Now it's working again. Note that this may not work for you if your lens is actually screwed up. Mine wasn't.
Dec 12, 2007 | Cameras
Sony cybershot dsc p5
probly has salt spray sticking the lens cover shut
Sep 19, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Camera no screen display
I wish this guy with the twist it blow it and bash it would take his advice eleswhere. He reckons it's the cure all for every digital camera with an extending lens. I've had a couple of the RR10s exhibit no life except a few flashes of an LED. The simple fix was to firmly squeeze the lower half of the camera's front and rear together. What happens is that either over time or if subjected to a slight shock the two main circuit boards part company at a rather large multipin plug and socket. Squeezing the front and rear (just above the hump at the bottom front of the camera)makes this plug and socket return to where they should be. The first one took me about 2 hours trying to figure out but the second took me about 4 seconds to get working again. WARNING don't overdo the squeeze be firm but not aggressive. I use both thumbs on the front and fingers on the back but stay clear of the LCD.
May 08, 2006 | Casio Exilim EX-Z4U Digital Camera
Kodak V803 Digital Camera Logo
50 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
