Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Convergence adjustments Can someone explane how to do convergence adjustments, or could e mail me that part of the manual. Thanks John I have a Samsung 42 in, rear projection tv model no, SP43W6HP, red and blue ghosting on screen, tried convergence without success, any suggestions?
  • caz66 May 27, 2008
    Thanks for the advice, have ordered the new part and will let you know if it fixes the problem, thanks again.
  • milnikos Oct 08, 2008
    the RED color is not conv. on green and blue,
I one the service manual pleas
Posted on Oct 07, 2008
  • Samsung Master
  • 8,617 Answers
Replace both convergence ICs nuber STK392-040 that should take care of the problem. you can get new replacement ICs at the following link and they will send free instalation instructions with pictures so you can install the new ICs. heres the link.
http://servicemanuals.vstore.ca/
Posted on May 27, 2008
Samsung ST42W5p
The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon.
http://www.fixya.com/support/r3342653-convergence_fix
May 10, 2010 | Televison & Video
How do you set convergence
What is your Make and Model number?
Mar 18, 2010 | Televison & Video
SONY KP-61XBR38
it could be either convergence or the velocity boards. Are you able to move the red and blue convergence in all four direcctions with the convergence adjustments?
Jul 12, 2008 | Sony KP-61XBR48 61" Rear Projection...
How to do convergence on a JVC 56 in rear projection HDTV
. It is more difficult than batteries on a remote.
You access the convergence board through the inspection plate that is located behind the front speaker grill.
You remove the board, determine if any resistors are burnt, replace any burnt or out of tolerance resistors, replace 1 or 2 IC's and re-install the board.
Now you have to adjust it to look like new.
If you haven’t misadjusted it too badly, do the auto focus and it is back to where it was before IC failed. If it is still misadjusted badly, then resistors may be wrong value or open.
If you live around Calgary, try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
or try the find a repairperson part of this website, maybe you will be lucky and someone is listed nearby.
Most rookies doing this job will cause damage and not be successful, and pay double for someone to fix their mess.
easyab
Jun 17, 2008 | JVC AV-56WP74 56" Rear Projection...
Problem with Samsung TV
SAMSUNG Convergence Problem
It looks like blue convergence. Look at menu, select convergence and see if blue top is bent down on convergence adjust screen. Probably won’t adjust.
Some Samsungs have convergence IC’s on a separate convergence board in the back of the TV. Others have the IC’s mounted on the main deflection board. Either way the board has to be removed to get at the dud IC’s and associated burnt resistors.
You remove the appropriate board, determine if any resistors are burnt or damaged, replace any burnt or out of tolerance resistors, replace 1 or 2 IC's and re-install the board.
If the unit has not been misadjusted and everything is OK now, running the auto focus may put the picture back to it’s previous stunning quality, as it was before IC failed.
If after self or autofocus it is still misadjusted noticeably, try the customer convergence adjustments. Operators’ manuals are available on web through searching.
If convergence can not be adjusted properly, you messed up chip install or resistors may be wrong value or open; or it needs major adjustment.
If you live around Calgary, Alberta try me instead:
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
Jun 06, 2008 | Samsung HCN4226W 42" Rear Projection...
One color Bow-tie Effect.
If the unit has not been misadjusted and everything is OK now, running the auto focus may put the picture back to it’s previous stunning quality as it was before IC failed.
If after Perfect Focus it is still misadjusted noticeably, try the customer convergence adjustments. Operators’ manuals are available on web through searching.
Good Luck
easyab
Jun 05, 2008 | Samsung HCN4226W 42" Rear Projection...
HCN4226W convergence board
SAMSUNG Convergence Board
I don't recommend working on the TV unless you have some experience and knowledge relating to the safety issues and electronic repair. Many rookies will not successfully complete the repair and probably do more harm than good.
Open the back of the TV. The board is in front of you, a small separate board with small plugs attached. If you think you are competent enough to remove it and replace it without damage to yourself or the TV, go for it.
Website below gives some description of costs with in home repair of convergence problems.
If you live around Calgary, Alberta try me.
Good Luck
Easyab
May 23, 2008 | Samsung HCN4226W 42" Rear Projection...
Manually adjusting convergence
convergance amp is might have a loose connection or be bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | JVC AV-48WP30 48" Rear Projection...
Panasonic Projection TV PT-47WX49E convergence ...
may not be convergence may be a bad stk for convergence if that style if so try stk
Oct 28, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Convergence off on PT-47WX49E
If it's really bad and happened all at once, your convergence amps have failed would need to be replaced before you could correct the issue with an adjustment.
May 22, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
333 people viewed this question
Henry  Thomas
Henry Thomas
