Question about Metrologic Instruments Voyager MS9520 Handheld
I just bought a metrologic voyager MS9520, the keyboard Wedge type. I can not connect it to my PC because my pc only has USB ports. Is there a driver that can help me convert the scanner to USB. I have USB adapter that I can use to connect the cables to my PC but I need a driver to convert the communication with the PC
SOURCE: Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
Posted on Jul 08, 2010
SOURCE: Can't even start Metrologic voyager 9520
The MS9520 with RS232 needs the AC adapter plugged in to operate, the adapter plugs into the serial cable at the plastic "bulge". Cable part number is 53000c-3
Hope this helps, Terry @ TAG Technical INC
Posted on Nov 25, 2008
rdiodoro
  • 13 Answers
SOURCE: Connecting Problems with Metrologic MS9535 BT
hi
that you have cable usb?rs232?ps2?
You have the power adapter?
you have windows xp?
is not difficult
Posted on Dec 17, 2008
  • 18 Answers
SOURCE: Incorrect Reading
Try experimenting with the different inter-scan code delays. You can find the programming barcodes in your manual.
Posted on Apr 02, 2009
  • 18 Answers
SOURCE: Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
Problem with metrologic voyager on xp,
If your voyager has the new interface then you can, by reading a barcode, change the type of connection. You must also change the cable
Sep 04, 2009 | Microsoft Metrologic MS9520 Voyager...
Voyager 5929 doesn't work with Vista
The problem isn't your scanner or Vista, it's your adapter. Power requirements and speed of data require special adapters. One I always recommend is Scan Technology's part # STI-PS2-USB. I've tested it with all Metrologic scanners and it hasn't failed yet.
Dec 30, 2008 | Metrologic Instruments Voyager MS9520...
Incorrect Reading
Aug 20, 2008 | Metrologic Instruments Voyager MS9520...
Mar 13, 2008 | Metrologic Instruments 9520 Voyager
Voyager scans into hyer terminal but not Notepad
Did you read the installation and configuration manuals? I download them from this website:
http://tinyurl.com/359pwh
Your scanner might note be configured correctly.
here are the guides I downloaded:
http://tinyurl.com/2sakgf
http://tinyurl.com/33gh4g
And the MFG website where you can download the material:
http://www.metrologic.com/corporate/products/pos/ms9520/
The scanner and host system must use the same communication protocol. I have a feeling the scanner is not configured correctly. The USB and serial connectors are 2 different types of configuration, but there are more.
You can also download the drivers and POS software from there website.
Feb 14, 2008 | Metrologic Instruments 9520 Voyager
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Metrologic Instruments Voyager MS9520 Handheld Logo
925 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
