We have a 20MF 251W Series LCD TV. After the set is on for approx. 20-30 minutes the sound goes off ???? After approx. 5 minutes it comes back on. Can we correct this problem? Please don't ask me to enter credit card information. I do-not want to pay for advice that you should give to your customers for free! Thanks
  • jfbill01 Oct 04, 2010
    What a shame, this was a replacement for the original we had problems with. We received the replacement in 2008. I don't think we will buy this brand again. Thank you for your help.
    If accurate, I guess it was helpful.
    President:
  • 2,777 Answers
Well first let me ask this, how are you a customer if everything is free? You are a customer of the TV manufacturer... and the store you bought it from.
Anyhow, it sounds like the sound board for the tv is going bad, also known as the S/T Con Board.... It is going to need to be replaced, I am sure the problem will continue to get worse otherwise. If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
Thanks
Tim
Posted on Oct 04, 2010
  • Tim Grayson
    Tim Grayson Oct 04, 2010
    If possible please come back to the question here and click the Accept
    This Solution button, otherwise I don't get credit for the help
    provided.
    Thank you so much,
    Tim
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
55" approx 5 months old.
The tv have a problems,with the board that call the Tuner signal board.This is the board,where the incomming broadcasting cable wire plug into this board.This a new tv,take it back where u bought it.Exchange it for a new tv replacement.
Mar 22, 2011 | Element ELC-HS321 32 in. LCD TV
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Will not switch on
There's a problem with the video card of the lcd TV  needs replacement .
some chip are damaged .or gets over heated eg processor .
Good luck
Oct 03, 2009 | LG 42LC2D 42 in. LCD HDTV
My sony wea lcd 60 inch television goes blank with no sound every 5 minutes or so for about 30 to 45 seconds then the picture and sound come back the set is just over 3 years old
Symptom shows TV needs new lamp and existing lamp is getting weak / dying.
Replace lamp in TV and procedure is written in user manual.
Let me know model number of TV if you need user manual copy.
Thanks.
Oct 02, 2009 | Sony Televison & Video
I have a Model LNT4061FX/XAA, Ser # AHBA3CSPB07786R, Version CN06 LCD TV. It is 18 months old and I have started to have a problem with turning the set on. When I press the on button it sounds as if it...
You Need To Do A factor Reset If You Are Getting A screen Go to Settings and look for factory reset that should help you get it back up !!remember that factory settings will lose all setting you originally had !!
We Are Here To Help!!
Aug 25, 2017 | Samsung Televison & Video
SAMSUNG 46 LCD 1080p series 5 - LE46A557P2FXXU - black screen
the x or y board may be bad in the set. i would say it is the main board.
Aug 11, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Thomson 27" LCD TV 27LCDB03B
cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
Dec 02, 2007 | Thomson LCDB 03B 27 in. Television
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
