Question about Kenmore 2205x Top Load Washer
I have Kenmore elite wahing machine and It's not working and giving me a code LD. What does it mean?
  • david_m_pags Oct 04, 2010
    What is the best way to drain the water and access to remove and test the pump?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you'll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 04, 2010
    President:
  • 1,554 Answers
It means long drain and flashes when there's no change in water level after the pump is turned on. Check to make sure that the drain hose is not clogged and the pump is working. Drain the water manually then lay the machine on its front on a cushioned surface to access the drain pump. Remove the inlet and outlet hoses from the pump then check and clean the impeller. Replace the pump if the impeller is damaged.
  • Jahn27
    Jahn27 Oct 04, 2010
    Drain the water through the drain and into a bucket or shallow basin then follow the instructions in the previous post then post back what you found after removing and inspecting the pump.
Kenmore Elite Oasis Washer Error Code Ld
LD probably means the LID SWITCH has failed
Aug 10, 2016 | Kenmore Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My Kenmore Elite Calypso wont stop washing
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
What does the code Ld mean???
Ld flashes when the water level does not change after the drain pump is on. ? Is the drain hose or the drain pump clogged? ? Is the drain hose height greater than 96′?
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does LD mean?
LD means long drain. There is a problem with the draining part of the cycle. You might be over sudsing or the drain hose is too low. Let me know if this helps.
Oct 13, 2009 | Kenmore Elite 45986 Front Load Washer
I Kenmore Elite mod# 110.22062102
The "Ld" error means long drain. May require a new pressure switch
Aug 03, 2009 | Kenmore Washing Machines
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 2205x Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
