Question about Dryers
How to remove the Blower wheel on an Amana Dryer?
  • kitzyinva May 28, 2008
    We believe that a sock or something else was sucked into the dryer lint compartment when the lint cover came off during a load to clothes. Can anyone tell me how to get it out? The tub will not turn and all the machine will do is growl when we try to use it.
    Novelist:
  • 177 Answers
You need to remove the blower assembly from the dryer.
First unplug the dryer.
Take care when you take the dryer apart, watching for SHARP edges
Take the dryer apart, removing the front panel and then the inner front panel of the cylinder. Before you go any further look at how the belt goes around the cylinder and on to the motor and idler pulley.
Now take the cylinder out, and remove the blower assembly, you will need various hand tools to hold one end of the motor and turn the blower wheel off. the blower may have an direct arrow on it to loosen.
While you have it apart vacuum out all of the lint, and put a drop of oil on the bearings of the rear wheels and idler. Blow all of the lint out of the motor.
Posted on May 28, 2008
How do i remove and replace dryer blower wheel and replace it.
HOPE THIS HELPS THE SCREW IS TURNED CLOCKWISE TO REMOVE
Feb 18, 2015 | Amana ALG331RAW Gas Dryer
Amana LEA30AW makes loud racket
either a bad blower wheel or you need to change out the rollers and belt pulley
Nov 08, 2013 | Amana NDG6800AWW Gas Dryer
Amana dryer mod. ned5100tq1 will not start. It only buzzes when i push the start button
Does it buzz or growl? Reach inside and turn the dryer by hand. Is the drum hard to turn? Might be a bad roller or possibly something stuck in the filter chute and lodged against the blower. I worked on a dryer exactly like yours and made a video. If the blower is clean and clear of obstacles and the wheels are fine then the motor needs to be replaced which is easy to do. The hardest part is getting the blower wheel off the motor (backward threads on it) Motor replacement video:
Manual and more is on my BLOG PAGE
Feb 24, 2013 | Amana Dryers
Dryer turns very slowly and makes a squealing noise. There is a burning smell coming from the dryer. What could be causing this?
The most common problem to date is bad blower wheel on certain amana older models on newer ones it is with blocked venting to outsde cause the wheel to overheat neatest the vent pipe and a resulting squeal and binding occurs. Remove the drum and check the rollers. Post the model number I might have a service manual
Oct 25, 2011 | Amana Dryers
How do i remove a damage blower wheel on a amana dryer model # ndg2330aww?
Then remove the front. Take the control stat off.
You will remove the drum and then 2 screws hold the motor assembly to the floor
Lift out the whole thing and sit it on a work bench.
Remove the screws on the face of the blower housing and the blower unscrews lefty loosey
like this:
I have one of these dryer out back. I went and took some pics. Did the video for you
More here
Aug 24, 2011 | Amana Dryers
Sock was sucked into lint filter. Was able to remove most of it by reaching through back air duct. A small part of the sock is still stuck, wrapped arounf something. How can I remove from lint filter? I...
Yes,remove the front panel to clear the jam. Carefully inspect the blower wheel after it is cleared. The blower wheel must not be loose on the motor shaft.
Feb 08, 2010 | Amana ALE443RAW Gas Dryer
The blower wheel is making a lot of noise. How do
Remove the front face of the dryer and continue to disassemble the dryer until you have access to the blower wheel. The blower wheel is manufactured with a D shaped hole in the middle. If the whole on the inside of the blower wheel become rounded, then the wheel rotates at a different speed than your motor, causing the loud vibrations you have been hearing.
Using the pliers, remove the holding pin & blower wheel clamp. The clamp is the green ring and the pin is the small horse-shoe shaped pin with an arrow pointing to it.
Pull the old blower wheel off. You should see that the whole in the center is round rather than D-shaped.
Put the new blower wheel in place.
Replace the ring clamp & holding pin.
Re-assemble the dryer.
Sep 01, 2009 | Amana Dryers
Amana Dryer 14 years old, turn on the dryer heats for about 10 minutes, then I hear noise like grinding noise and the heat turns off?
Remove the front panel and check the blower wheel on the motor. If it turns freely on the motor shaft replace it.
Aug 30, 2009 | Amana Dryers
Amana dryer model #LG4309W doesn't heat up like it used to
you need to get a vent cleaning the recommend that you get one evey 6 months with a gas dryer.
Dec 10, 2008 | Amana ALG443RAW Gas Dryer
Dryers Logo
229 people viewed this question
Top Dryers Experts
