Question about Camping, Backpacking & Hiking
Alkaline (D) batteries leaked and are stuck inside a Mag Lite. Need advice on getting the batteries out.
  • 283 Answers
The best way to get them out is to remove both ends and tap them out with a solid object. What has happened is they have exploded and expanded against the walls.
Posted on Nov 02, 2010
  • jeff_berk Dec 04, 2010
    Contact maglite. According to their web site they will replace your flashlight either for free or at a very reasonable cost depending on what brand of battery you have in it.
3 cell mag 1 battery came out the other are stuck. how do i get them out?
Hello, don't bang on the mag lite. Take a four inch deck screw and screw it into the battery one a time. Once the batteries are out. Mix up some water and baking soda.paste Take the soda paste and applied inside the tube around the corrosion areas. Rense with water and paste serveral times until the inisde of the tube is cleaan. Remove all components from mag lite be starting this operation. Wipe out with clean cloth and skake until al lwater is removed. GB ....stewbison
Aug 26, 2011 | MagLite Mag Instrument Mag Lite 2 "D"...
Have large metal flashlight with D batteries inside am unable to open end to replace batteries. Tried wd40 and it did not work
A possibility that the batteries have leaked a caused a galvanic corrosive issue, binding or fusing the end cap. See the manufactures instructions for removing and installing batteries.
Aug 25, 2011 | MagLite Mag-Lite& Flashlight
I just replaced the batteries in my 2 D LED maglite with duracell alkaline batteries and after about 5 minutes use seem to have blown the led. Torch is less than 1 year old and has had limited use. Looking...
The resistor needs to be disconnected at one end -- if the LED is removed this should have the same effect as disconnecting one end of the resistor.
Put the probes of an ohmeter on each end of the resistor -- if it reads 0 ohms (or near zero), it is shorted.
Charlie
Mar 26, 2011 | MagLite Mag-Lite& Flashlight
The last battery in my 3-cell Maglight (closest to the end, farthest from the bulb) has leaked acid out inside the tube /handle and caused the battery to get stuck, I can't get it out to clean it up and...
Unscrew the lens and remove the bulb, then get a small disposable container and fill it about an inch full with WD-40, or a similar de-seizing fluid. submerge the stuck end in the fluid for a few minutes and it should come off without issue. Make sure to clean the tube completely before replacing the bulb, lens, and batteries.
Feb 28, 2011 | MagLite Mag-Lite& Flashlight
Got a a six cell Mag Lite D and the batteries have corroded and jammed inside.Got 1 out, 5 stuck fast. How do I get the damn things out!
The bad news is, the torch will likely not work even if you could remove them which is unlikely. The acid will have rotted the business end of the torch terminals. Time to throw it in the bin my friend.
Dec 19, 2010 | MagLite Mag-Lite& Largehead Flashlight
MAG-Lite flashlite with Battery removal problem
Pull the cap off the end and wack it in your hand or a piece of wood, don't swing it like a baseball bat. Sometimes they get stuck in mine also, Not sure why, but a good wack gets the job done. Don't worry, the flashlight can take it.
Feb 04, 2010 | MagLite Mag-Lite& Flashlight
How do I get swelled and leaking battery's out? of my 4 D cell mag light, the one on the end came out but the next one is stuck. I tried a few drop of vinegar to neutralze and thin the alkalie goo,...
I found some info on this site...
http://cr4.globalspec.com/thread/14899/Leaking-battery-stuck-in-Mag-Lite#comment150608
"Sadly, when a dry cell leaks, the leaking chemicals react with the torch casing, as you have noted.
With all Maglite torches I have ever seen, you can remove both ends of the cylinder which encloses the batteries.
In this situation, get a broom handle or wooden dowel, just a bit smaller than the torch battery diameter, and after soaking the cylinder/switch assembly cylinder in hot water (boiling if you can) for an hour or two, give that inserted dowel a few taps with a large hammer or mallet.
Normally the leaking battery comes out easily, providing you let it soak in hot water long enough to soften the corrosion products.
Once you have gotten out that battery, leave cylinder soaking overnight, and use an old toothbrush to remove the last of the oxide etc , and allow to dry thoroughly.
As a tip for next time - to save you all this bother: Oil or grease the inside of the torch cylinder, and re-coat with oil (silicone grease is best), each time you replace batteries.....smiley-cool.gif"
hope this helps you.
Jan 19, 2010 | MagLite Camping, Backpacking & Hiking
Bulb holder is broken
Just buy a new one the bulb holder cost around 18.00
Please rate fixya!
Feb 24, 2009 | MagLite Mag-Lite& Flashlight
Batteries stuck in torch
I had the same problem same mag lite.
After removing the lamp ect I soaked the barrel and batteries in WD40 for a few days. Using a soft faced mallet hold the torch in one hand and few sharp blows later the battery was dislodged. I must admit there was not a great deal of corrosion though. I then cleaned out the barrel by wrapping Carborundum paper around a broom handle inserting it into the barrel and just reamed out the barrel cleaned all the swarf out with tissue on the stick sprayed a drop of the WD40 into the barrel and its worked a treat ever since.
Regards
Jan 17, 2009 | MagLite Mag-Lite& Flashlight
I have a mini Maglite with one battery stuck in the barrell
I had a similar problem. My wife put two AA rechargeable batteries into her mini maglite. Apparently the AA rechargeables have a slightly larger diameter than alkaline batteries. One of them was stuck in the barrel. I was able to remove it by first removing the lens and bulb so as not to break it. Then I slammed slamming the barrel down hard onto the carpet on our floor. This hard shock jarred the battery loose and it came out of the barrel. Hope this helps someone out.
Jan 15, 2009 | MagLite Mag-Lite& Flashlight
Camping, Backpacking & Hiking Logo
416 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
