Question about Proview PL913S 19" Flat Panel LCD Monitor
Flat screen monitor
When I turn on the computer, my monitor's screen is all white. I have to turn it off several times before the screen comes on. What can I do besides purchase a new monitor
  • dnolle Jun 25, 2008
    White screen when cold. I connect and disconect from laptop daily. Can occasionally get screen to show with long power-off or cold boot of monitor.
  • Anonymous Oct 01, 2008
    My screen is okay when the computer is restarted. Once it sits for a while, it comes back: a white, hazy screen that does not allow me to see the mouse cursor.
  • 558 Answers
I would open the monitor and look for bad capacitors on the power board
Posted on Feb 17, 2009
The problem started with frequent occurances of "white screen." I am not a computer geek by any stretch of the imagination but I was able to get it working several times by rebooting, turning...
Suggest connecting monitor to another computer and confirm defect. If problems reoccurs and cables are confirmed OK replace.
dims-mvjfcvkh3nvffkljjmexfvsy-5-0.jpg Common problem capacitors failing in computers and components.
Soyo 2286 LCD Monitor Repair Tutorial
Jul 04, 2017 | Soyo DYLM2286 Monitor
My monitor has sound and the little green light is on, but the screen is black no matter what I do. Tried rebooting, checked connections, shined flashlight, etc. I've noticed over the past few days, the...
Make sure it is plugged into the right connector on the back of the pc. If you have intergrated video and a later installed video card make sure it is plugged into the right one. Does the monitor say "no signal"? Have you tried a different monitor to verify that the connection works. Also try a different cable, as the cable could be bad.
Nov 16, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
I have a Proview PL716S and sometimes the entire
ur monitor got err i need to be changecoz repairing of monitor is unprofit
Apr 14, 2010 | Proview PL916S2 Monitor
Monitor does not come on right away, it makes a clicking noise then say no signal analog. after i trun off and on several times it comes on but the screen is wavy for a while
when you say the screen comes on wavy for awhile, im supposing you have a CRT monitor, not the flat panel type. That seems to be the degauss feature when you turn on the monitor which is normal. The no video issue may be a bad video cable or connection the the PC.
Nov 09, 2009 | Computers & Internet
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Monitor won't start when I boot up - without a lot of fiddling!
First try to do monitor self test.Disconnected the blue cable VGA or white colour connector from monitor to the computer. Turn on the monitor and check if you are able to see colours or line on the monitor.Indicating self test monitor is working fine. If you are using Video card on computer connect monitor directly to onboard video and check. Good Luck.
Aug 19, 2009 | Computers & Internet
White screen on monitor
o cant suggest anything appart from buying a new one sorry.
please rate my help to you.
thank you
Apr 22, 2009 | Dell E173FP 17" LCD Monitor
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Proview PL913S 19" Flat Panel LCD Monitor Logo
95 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
