Question about Coldtech 61 cu. ft. / 1727 liter Commercial Freezer J6SFF-61B
J6SFF-61B Manual Where can I get a manual for my Model J6SFF-61B Freeser???
You still looking for the manual for your freezer. if so send me an email where I can send you a manual and the diagrams
Posted on Sep 20, 2008
  • 828 Answers
Try this number and ask for an owner manual (800-314-4477)
Posted on Jun 01, 2008
Freeser will not go below 40 degrees
Dirty coils, or refrigerant getting low
Mar 29, 2014 | True Freezers
Ariston fridge/freeser BCB31AA
Call out the warranty supplier. Where is the noise coming from? If no warranty, check the electrics to the compressor and fan. sometimes the noise is the fan. Also switch off overnight and leave doors open. When restarting, if the noise has gone it will have been the internal fan hitting on ice buildup.
Mar 25, 2014 | Freezers
The frreezer runs more then it is off. I have it set at 00 and i can watch the temp go up to 04 in less then 5 min is this normal. I had someone come out and charge the systems.
If refrigerant was added (freon), then one of 2 things may be going on. First, he could have overcharged the system. Too much freon. Second, it was low on freon. If it was low, then look for the leak as it will only get low again. The refrigeration system is a closed, sealed system.
When temp rises rapidly, it could be that one of the doors are not seal well. I have only had one unit in my years of experience where the unit would gain enough temp to cycle the unit on in about 2 minutes. Never was able to find the answer but the unit never failed and no food was ever lost.
Apr 12, 2011 | Coldtech 61 cu. ft. / 1727 liter...
Freezer not cold enough
the dryer is already sock ,, you need to change it and refill the gas
Jan 24, 2010 | Freezers
How do you take the freeser out of defrost?
http://www.hoshizakiamerica.com/manuals/KM-500M_H_serv.pdf
http://www.hoshizakiamerica.com/manuals/KM-500M_H_pts.pdf
Go to this web site. You will find the service manual and the parts manual. Look on page 4 of the parts manual. Look at item "C" with circle around it. This is the water float. It is probably stuck. If it does not move during start up, the machine registers as if there is no water in the sump so it stays in the "Fill" cycle and will not go into the freeze cycle. Tap on this and see if it starts to function. You can also drain the water out of the sump and take this float apart and clean it. Just be sure not to break the small rod across the bottom of the assy that holds the float in the assy.
Good Luck and hope this helps you out.
Jul 31, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Coldtech 61 cu. ft. / 1727 liter Commercial Freezer J6SFF-61B Logo
330 people viewed this question
Top Coldtech Freezers Experts
Dennis Boxerman
christian nielsen
Are you a Coldtech Freezer Expert? Answer questions, earn points and help others
