Question about Brother Sewing Machines
Presser foot stopped working I turned
Presser foot stopped working I turned my machine on put my foot on the presser foot and my machine said E1 and it just wont run
    Genius:
  • 1,788 Answers
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Posted on Oct 04, 2010
Pfaff ambition 1.0 sewing by itself
sounds like there a problem with the motherboard giving the wrong
commands. the machine definitely needs to be checked.
Sep 11, 2012 | Sewing Machines
Brother 834dp, entire machine is locked up??
the best thing would be for the machine to be serviced
Mar 08, 2012 | Sewing Machines
HOW DO I ATTACH PRESSER FOOT G TO MY MACHINE??
there are 2 type of presser bar foot clamps
one allows you to snap on the foot--raise & then lower the presser foot holder until the cut out is directly above the pin on the foot,,as you lower the presser foot holder the presser foot will automatically engage when put down on the pin area
the second is a shank & foot combined & there is a screw on the presser bar,,unscrew it some & put the shank up around the screw & retighten the screw
Nov 24, 2010 | Janome Memory Craft 5700
The machine keeps giving me an error message with a diagram showing the foot should be down. It is, but it won't sew anything. I can thread a bobbin, so I know there is power to the machine. Also, when...
that presser foot with that black thing that is just flopping around... well when the presser foot is down that thing should be locked into the side hole. when you have the presser foot up, put it into the side hole, fiddle with it, move it around til you find that hole, then drop the presser foot it should be locked on it now. That T presser foot needs that.
Aug 23, 2010 | Euro-Pro Sewing Machines
Presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Nov 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
How do I install my darning foot?
First, raise the presser bar, remove the presser foot, the presser foot holder and screw.
Turn the handwheel to bring the needle to its highest position.
Place the darning foot on the presser bar and make sure that the metal bar of the darning foot is above the needle clamp and put the screw back on and tighten.
As the needle bar raises and lowers, the foot will hop up and down slightly.
Make sure that you always lower the presser bar when using this foot. Lower the feed dogs also if your machine has this feature.
Aug 20, 2009 | Kenmore 15343
I am trying to embroider something for the first time on my viking #1 husqvarna. Do I need presser foot Q/ or R/ .If it's R,I can't find it-what does it look like? I need someone to walk me thru the steps...
embroider on #1+:
If it's a #1+ I recommend the Q (the spring works better) it's hard to put on, but worth it.
Here we go:
1>Turn off machine (always when installing or removing embroidery unit)
2>Install Q Foot. Always leave presser foot pressure (on left end of machine) at 6 for presser foot Q
3>Insert Embroidery Card
4>Insert Embroidery cassette (matching #’s with card)
5>turn on machine
6>Turn on embroidery unit (on cassette)
7>Select design
7>Thread for color 1
8>press reverse to start the machine embroidering....weeeeeeeee!
Jan 18, 2009 | Husqvarna Viking 1
Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
May 05, 2008 | Husqvarna Designer I
Presser foot down, but still get error "E1"
I have a different model with the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
Mar 26, 2008 | Brother CS-100-T Computerized Sewing...
Sewing Machines Logo
391 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
