Question about Magic Chef MCBR360S Stainless Steel Compact Refrigerator
I'm looking for the same part as the gentleman above which is P6R8MC with a second number below OR0411 but it happens that I only found OR0401, does this make a difference? Thanks in advance for you response. Manuel.
Where is my engine id on a cw 50 cc zuma from2003?
hello, you will find the vin number in two places, the first being a white sticker located roughly where your knees would be on the rear of the front panel, the second and the one that engineers will want to know about is engraved into the frame and located inside the small rectangle panel just below that sticker. the engine number is found at the rear of the bike just above the air cooler system and drive belt please see pictures, pic 1 - vin and pic 2 = engine number
Apr 22, 2015 | Motorcycles
Amana bottom freezer temp 16 below. Turn temp down a little temp goes to 20 above
With that kind of spuratic actions I would strongly lean toward that the temperature control, also know as the cold control , is probably malfucntioning. Before I can 100% call that fact I would need more inforamtion, model number the most important. Also, a description of how the machine looks on the inside, like frost on the wall, ice, etc.
Apr 29, 2012 | Refrigerators
Clearing fax numbers from my brother mfc 8220 printer
press menu*2864, display will flash, then enter 01 on the keypad,wait 30 seconds and then press 99 on keypad, machine is now returned to factory settings
Nov 20, 2011 | Brother MFC-8220 Fax
Yüklemek istiyorum cd kaybettim 2002
0.) (yüklemek istiyorum cd kaybettim 2002 = I want to install lost cd 2002.) Left of the equal sign was auto-detected as Turkish-numbers and symbols included!!!) After going to google translate I found what I'm fairly certain is a need for drivers and software/utilities for this gentleman's slightly older, but very good quality Logitech webcam.
1.) Locate your hardware device model/product/serial number. Write this down as it beats taking down and putting up your cam over and over, and its clearer and less prone to mistakes.
2.) Go to Logitech's web-cam identification support webpage (http://www.logitech.com/en-us/support-downloads/downloads/webcams)
3.) locate your particular model web-cam. the webpage is very nice with high quality graphics of many webcams and lists the model numbers directly below each picture. the pictures are great and often times i find my camera of choice before even looking at a model number and do that usually as a verification rather than a search technique. please do verify as a wrong model at this stage is going to prevent your installation before it even gets off the ground!!! :)
4.) If you're using an older web-cam, and you find that you can't find your old beast among the shiny new cams, go to the bottom of the webpage and look to the right hand side for a link that reads: Still can't find your product
this is the link to the legacy products webpage. go ahead and click to the legacy page and have a look for your camera.
5.) In under three seconds [How's that for search engine results, eh? :)] I have located what I'm fairly certain is the camera in question. the name matches and the picture is a dead ringer. All that's left is to compare the model numbers for verification and we've got our cam! this web-cam is located in the fourth row from the top in the first position [picture hopefully attached below! :)]
6.) Clicking on either the image or the name of the cam will take you to the support web-page for this product/web-cam. http://www.logitech.com/en-us/480/3403?WT.z_sp=Image
7.) And once there all your web-cam dreams and wishes have come gloriously true!!! Logitech is an incredible company with excellent products, and in my opinion, one of the finest support sites, bar none, on the planet!!! Here is an entire web-page complete with links to every imaginable aspect of your product, including forums, faqs, driver and software downloads, community, troubleshooting and more. It is an awesome array of 'everything' just for 'your' product. And it's there just for you!!!
8.) Okay, I believe my job here is successfully completed and so I will leave you to wide-eyed gazing and hushed giggling and yes, downloading everything your great little web-cam can possibly use and then-some (don't forget the new/updated software with all the coolest features your web-cam only dreamed of providing you!!!
9.) towards the top-right is the link for drivers and software:
Download installation software, drivers, updates and more.
In this link you will find drivers and software for Operating systems Windows 98, ME, 2000 and XP. With a quick peek I found these drivers (QuickCam Driver v8.4.8. and Image Studio for QuickCam v.7.30 available for ALL the above mentioned operating systems and in over 12 different languages.
Feb 10, 2011 | Logitech QuickCam Express Web Camera
MY FRIDGE STOP WORKING AND THE COMPERSSOR IS VERY HOT. What can be wrong with it it is only 2 years old
Usually when a compresso that is not that old gets hot the problem is with one of 3 components
1. The PTC Relay PN P6R8MC
http://www.repairclinic.com/SSPartDetail.aspx?s=t-P6R8MC-%3d%3di1206838&PartID=1206838
2. Thermal overload PN 265RFBYY
one of many sources: http://www.repairclinic.com/SSPartDetail.aspx?s=t-265RFBYY-%3d%3di1206539&PartID=1206539
3. Loose wiring or terminals
4. Worst case the compressor itself (5 Year carry in warranty!)
Items 1 and 2 above should be changed at the same time. Usually when one fails it causes the 2nd one to fail.
Before you go ordering parts.. just unplug the unit for about 45 minutes. Sometimes if there is a brief power outtage (less than 3 mins) the unit stops and the coolant has not equalized. The compressor keeps trying to start keeping the pressure up but yet the compressor does not start normally. The compressor gets hot and the thermal overload causes the unit to cycle on about every 5 minutes. Over an extended time of cycling the thermal overload will fail. After 45 minutes plug the unit in and see if it starts
If you change the PTC Relay you must change the KliXon thermal overload at the same time. Most LOCAL Appliance part supply stores will have both of these parts in stock. Use the part numbers above and walk in with the parts in hand.
IF you decide to change them your self FIRST make yourself a simple wiring diagram
I.e Orange to terminal ___
Blue to terminal ____
Then remove the parts by opening the plastic cover on the side of the compressor and then pull off the PTC and Thermal overload HORIZONTALLY. Obtain the replacement parts and reintall after inspecting the compressor terminals. Clean as necessary by scraping with a knife blade.
If after changing these two parts the compressor still does not start you may very well have a warranty carry in service compressor change. I seriously doubt that the compressor has failed but it does rarely happen.
This is the Magic Chef support website for parts (linked page) and warranty (top of linked page)
http://www.mcappliance.com/partorder.aspx
Thanks for choosing FixYa.
Kelly
Sep 17, 2010 | Magic Chef MCBR360S Stainless Steel...
Trying to find out correct year of manufacture for a 115 johnson V4 but dont know where the serial no. is? I have found a no. on the mounting bracket.
All of the engine model numbers will look like this:
115MLCI 115 1981 115MLCN 115 1982 115MLCO 115 1985 115MLCR 115 1984 115MLCS 115 1980 115MLCT 115 1983 115MLES 115 1990 115TLCI-115TXCI 115 1981 115TLCN-115TXCN 115 1982 115TLCO 115 1985 115TLCR-115TXCR 115 1984 115TLCS-115TXCS 115 1980 115TLCT-115TXCT 115 1983 115TLES-115TXES 115 1990
It should be on the port side of the transom bracket(On the engine to boat mounting bracket). If not, look around on the engine block for a small silver plug (It will look like a shiny freeze plug) There will be 2 sets of numbers... one of the above numbers and your serial number will be the second number.
Apr 01, 2010 | Boating
Magic Chef MCBR360S Stainless Steel Compact Refrigerator Logo
212 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
