Question about Samsung Televison & Video
The picture on my samsung LE37M86 television looks washed out and dark. Some colours seem too bright, while others sink into a generic grey, and the picture artefacts stand out a lot. What could be causing this?
SOURCE: Samsung LE37R8 Picture in Picture
Picture in picture will only work if you have a pc connected......
Posted on Dec 14, 2007
VOTIT
  • 2071 Answers
SOURCE: Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Posted on Sep 21, 2008
  • 197 Answers
SOURCE: Samsung 46" LCD picture dark at one side of the screen
bad panel
Posted on Jun 07, 2009
SOURCE: Vertical dark line down screen
http://www.avforums.com/forums/sony-owners-forum/1165140-faint-lines-kdl32s5500.html
I have also experienced the same problem on two occasions, but my Sony TV KDLV3000 has actually been backwards and forwards on three occasions to be repaired. I have had a new control unit and will be having a second screen replacement shortlymad.gif. I have contacted my local Sony Centre and they have stated that they will only replace the TV if there are THREE IDENTICAL faultsfacepalm.gif.
COME ON SONY CENTRE GET YOUR ACT TOGETHER AND TAKE A NOTE FROM JOHN LEWIS THERE CUSTOMER CARE IS SECOND TO NONE.
Not sure I'll buy a Sony again after this experience having been a loyal Sony customer for a number of years, will probably look at a Samsung or LG next time.
Posted on Jan 20, 2010
Testimonial: "Thanks for your comments. Very useful."
SOURCE: I have had this 32
i need to hook up a 3 way switch
Posted on May 01, 2010
Colour is not normal, sometimes the picture is too dark, football pitches bright green, peoples faces very orange.
that would be a failing tcon board on the back of the screen.you would need to replace this part but they are available on ebay the part number is on the tcon board. match the numbers a version number to get the matching board for the screen. tcon board is the board were the main wire cluster goes to the screen board this is the tcon board.
Jul 03, 2017 | Samsung LE37R72B 37 in. HD-Ready LCD...
Picture is dull, not bright looks grey
Have a look at the three lens this model should have, if dirty or dusty clean with a lens cloth, also peek inside and up to the rear to see if the mirror is dirty.
Dec 07, 2012 | Samsung PCL5415RB 54" Rear Projection...
Picture is not bright looks grey
if you are watching a local channel tried to move in other channel just to ensure if the same issue, if the same the cause is with in the tv. if just only in some channel might have problem in the channel program.
Dec 07, 2012 | Samsung PCL5415R TV
My screen seem to be really dark. I just got the TV from my older brother, hand me downs. What could i do to make the picture more clear?
Hi Friend,
Try to reduce the Display Colour and the Brightness of the picture and then check it
Regards,
Ayyasam
Apr 03, 2010 | Samsung PLH403W 40" Rear Projection...
Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Aug 21, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Dark pictures
perhaps the lab is at fault? if iPhoto displays the pics with the correct dark/light profile then it is likely to be right. You can alter the profile in the edit window of iPhoto but it would seem the lab messed up.
Dec 12, 2007 | Casio Exilim EX-Z40 Digital Camera
Rear projection dark picture
Open up the front of the set and find the screen controls and perform a grey scal alighnment by adjusting the red , blue , and green screen controls but be carefull and make sure you adjust them evenly or the picture will not look right. Good Luck
Mar 23, 2007 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
249 people viewed this question
Jerry Greenberg
Jerry Greenberg
