SOURCE: Bosch Model WFB 1605 washing Machine
Try online...you'll need the full model from the machine. Try general search or go to bosch's web
SOURCE: BOSCH WFMC3200UC WASHER
Go to http://www.repairclinic.com/SmartSearch/smartsearch.aspx and type WFMC3200UC under search at top. Then select gasket/seal/o-ring from part type drop down menu.
SOURCE: The door seal on a Bosch WVT1260DB01 FD8609 has
There is another clamp or spring depending on which is fitted.
Turn the door seal in on it'self, and you should be able to feel or see the second retainer, if it is a spring, get something to hook it out with, if it is a clamp, then it will have to be unscrewed.
Please rate my solution.
Thanks.
Hi
I have a user manual - swedish, Suomi, Norwidian and danish
