Question about Ovens
Hi my oven is 75775890 it is a Kenmore Plus Gas Oven. The problem is the oven is not heating. The pilot light is lighting, but it is not extending once it is lit. I am trying to find out what it needs to be repaired. Thank you
  • 25 Answers
SOURCE: lighting pilot of GE gas stove
According to the model number you supplied it looks like your oven use a glow bar ignitor not a pilot light. In that case there is no place to hold a fire. what happens with these when you turn the oven on 120 volts goes to the ignitor causing it to heat up ,the amp draw across the ignitor causes the gas safety valve to open, and then lights the gas. So if you turn your oven on you should see a bright red glow if not probably the the ignitor, to check it you would have to verify you actually have power going to it. If the ignitor glows but the gas valve does not open you will still need to replace the ignitor has to pull about 3.2 amps across ignitor to open safety valve. Your broil burner works the same way. And most of the ovens the floor of the oven comes out to allow easier acess to the ignitor. also if you have to change the ignitor put just a dab of dish detergent on the screws to help from stripping them
Posted on Feb 23, 2008
  • 1314 Answers
SOURCE: Roper gas oven won't work
replace the thermal coupling on the pilot make sure it is in the flame of the pilot it looks like a copper wire or tube if its bad it wont open the gas valve after the pilot heats it up
Posted on Mar 02, 2008
SOURCE: oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Posted on Apr 21, 2008
bigg t
  • 640 Answers
SOURCE: Oven pilot light will not stay lit
The thermocouple is bad this is the probe that sits next to the pilot,the pilot flame heats the thermocouple and then it sends a micro voltage to the valve to keep it lit.Goto hobartcorp.com and find your model then the part number.
Posted on Sep 04, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore gas oven won't heat up
If your ignitor is coming on that means the oven control is supplying the power to the ignitor and gas valve. So the gas valve is ok because it is allowing for a complete circuit so what the heck is wrong? The ignitor MUST draw 3.5 amps in order to open the gas safety and allow the gas to come out. The ignitor must be very bright, if it is dim then it is bad. (MORE)
Posted on Feb 09, 2009
Kenmore Oven- The oven doesnt heat or light at all. If I sent it to 350 degrees; should i still smell gas?
I beleive this model has an electric igniter, You may have to change this they sometimes just wear out, or it's just simply your pilot light is out and you need to relight it, hope this helps.
Sep 19, 2012 | Kenmore Ovens
I have a garland oven model st286 it wont light even though there is gas getting to it and the spark is working. It lights if you light it manually
Instructions
  1. Access the burners inside your oven by removing the access panel in the front of the oven or by opening the broiling drawer, depending on your particular model.
  2. Determine if the pilot itself is lit, since some ovens have a small flame on the pilot at all times that then grows and extends to the burner when the oven is turned on. The lack of a pilot flame indicates the oven thermostat is malfunctioning or there is a problem with the gas hose. Check the pilot itself to see if it is clogged with debris or grease that could be preventing the flame from staying lit.
  3. Determine if the pilot flame will grow if it is lit by turning on the thermostat. If the pilot flame doesn't extend, the thermostat itself likely needs replacement. If the flame is extending but the gas valve is not opening, the safety valve could be dirty or defective. The flame should be blue in color. A yellow flame indicates the pilot is dirty and is not burning hot enough to get the main burner to ignite.
  4. Light the burner on the top of the oven with a match if the igniter doesn't appear to be effective. If it lights manually but will not light automatically, the igniter is likely faulty. Do not do this if there is a heavy smell of gas in the kitchen, since there could be a risk of a fire. In that circumstance, turn the oven off, ventilate the room and call a technician.
  5. Listen for any sounds of gas hissing or a clicking sound indicating the oven is trying to turn on. If there is no response from the oven at all, the gas may not be functioning properly and will need to be examined by a technician for safety purposes
Jan 26, 2011 | Ovens
Our Kenmore oven has stopped working. We were thinking it had something to do with the pilot light going out, since we do smell gas when we turn the oven on. Can you tell us where the pilot light might be?...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 09, 2011 | Kenmore Ovens
My sears kenmore gas oven isn't working. Maybe the pilot light is out? I can't find where to relight.
heatman101
Nov 04, 2010 | Kenmore Ovens
My oven is not lighting and it doesn't even smell like it is getting gas to it. I do not see any pilot light lit but even when I try to light it there is nothing yet the stove works fine. Any idean of what...
heatman101
ghdhdg
Jun 02, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My Magic Chef is a 1979 gas oven and it won't light
OK, you will need to watch the pilot when you turn the temp control. It should get longer and give heat to a coupler that should be attached to your gas valve. If the pilot does not extend when you turn the temp control then the temp control is bad. if it does then your valve is bad.
I hope I got the right kind of machine doing this blind.
Jan 07, 2010 | Ovens
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Oven does not heat up, can smell gas.
You probably need an oven igniter, it's weak. Remove oven bottom and find caged unit attached to burner. Replace this oven igniter. The 2 wires can go either way.
Nov 22, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
149 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
