Question about Sony Cyber-shot DSC-S600 Digital Camera
Hello when power on my camer My camera display "Turn off and restart"
  • 231 Answers
Dear sir,
the first suspect is your battery,ahich is running in low battery....kindly recharge the battery for few hours and then put your camera on........
next,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest samsung service centre
thank you.....take care................
Posted on Oct 04, 2010
  • vijay kamal
    vijay kamal Oct 04, 2010
    dear sir,
    next,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest sony service centre
Can see one line on display of micromax q5
hello! are you looking for the camera flex cable (line). if you looking for the camera replacement,please kindly open this 2 links. you may find the item you want and then slove your camer problem immediately.
www.skiliwah.cn/
http://www.digitalcamera-parts.net/
MSN:e-8090team@hotmail.com
cindy
Aug 17, 2011 | Cameras
My camer says lens error,restart camera waht do I do?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Apr 27, 2010 | Canon PowerShot A1100 IS Digital Camera
When i connect the camera to the pc (have already selceted pc as the usb mode) the camera says ''connecting to pc'' but never actually connects. how do i fix this...have read manuals and no joy! please...
Hello. This method has worked for me in the past. Turn off PC, make all connections , turn on camera and restart computer. If this works your done.If not and your using Windows open cotroll panel and then using the classic view open Add Hardware try using the wizard to find your camer
builderdale
Jan 17, 2010 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
Lens error restart camera but it just switches off i keep getting a lens error restart camers error i turn it off and on but get the same error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 28, 2008 | Canon PowerShot SX100 IS Digital Camera
Lens problem
I have had the same problem with a different camera, the problem started when I did not have sufficient battery charge to turn the camera off completely. The camera shut down, but the lense did not retract.
You can try a few things:
First try remove the batteries and holding the power button as if you are going to start the camera, then reinsert and try again. (make sure they are fully charged first)
You can try connecting the camer to the computer before you turn it on. Connected to the computer the camer goes through a slightly different start up procedure.
Try switching it to playback mode on restart.
If these fail I have a couple of tricks up my sleeve, but need to know the answer to these questions:
1. has it suffered water damage?
2. has it been dropped recently?
3. what happend when the lense did not close properly? Is this the first time?
4. Can you access the menus when "restart camera" is on screen?
Just post a comment back
Jun 13, 2008 | Canon PowerShot SD1000 Digital Camera
I have and n2 fault code showing on my display
I think you're losing power. Try flipping out the battery.
Oct 26, 2007 | Olympus SuperZoom 115 QD 35mm Point and...
Sony Cyber-shot DSC-S600 Digital Camera Logo
23 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
