Question about GE 29488GE2 Corded Phone
GE 29488 My line 1 is inactive and the error message says that it is inhibited. My line 1 in-use button changes from red to greenish and intermittantly says that it is in use. I cannot transfer to this line or speakerphone this line and the calls are not ringing in. Help! Chris
    Problem Solver:
  • 7 Answers
This phone also uses line one as the background carrier for the intercom feature. If line 1 is inhibited this means that the phone is not showing the correct line voltage on line 1. The phone believes line 1 is dead. Use a regular phone and check line one for dial tone. If as the other reviewer is correct, and you are using DSL on line 1 you will need to place 1 filter on the incoming line and feed all of the phones after this filter. This means of course that your computer connection will have to be made at the D-mark as you will have filtered out the DSL to all of the phones beyond this point.
Posted on Dec 29, 2009
  • 549 Answers
Note: Intercom features are NOT compatible when DSL is installed on line 1.You may need to reconfigure it for dsl internet if it is installed on line 1
Posted on May 27, 2008
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Messaging is inactive on all lines after push functions button and enter 981
Hi. Inactive feature often means that there's a problem with your connection to the call pilot. Do you have lights on your call pilot? Did you assign a mailbox to the extension you're working on? Did you remember to connect the call pilot to a station port?
Jun 11, 2015 | Nortel T7316E 2-Line Corded Phone
WHAT THE SYMBOLS MEAN
From left to right:
(Lights)
Exclamation point: Error
Weird Monitor beat symbol: Jam
Paper: Out of paper
Toner (Triangle leading down to dot pyramid): Toner refill
Lightbulb: ready
(buttons)
Greenish Play button (square with triangle): Continue
Red button with x: Stop/Cancel
Dell 2230 User Guide Page 1
Mar 27, 2013 | Dell 2230d Laser Printer
I have a sony ericsson J10i2, I bought it off ebay, it's saying i have an inactive sim, and there's a handset next to the network bar with a red line through it. I have signal on my phone, but i can't make...
Hello and Welcome to FixYa!
Inactive SIM message may arise due to more than one issues. First things first check the hardware of your phone, to do this Put out the SIM card and check what happens. If it shows insert SIM card, its normal. If it shows the same inactive message then hardware malfunctioning.
Ok if the hardware is ok, then its simple. Inactive SIM means that your SIM card is not being able to register your Network carrier. The Phone with a red-line means SIM card registration failed. Although the signal radar works. This may be due to 2 issue; either there is a issue at the Service provider End, to check this call the service providers from other cell or land-line and check the status of your connection against this SIM Card No. If they say everything is ok. Then Its confirmed that your Phone is Network locked (Can only be used for one specific network) In this case coordinate with the seller.
I hope you will have a clearer picture now.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Mar 15, 2011 | Sony Ericsson J220a Cellular Phone
The intercom button keeps flashing red and green and it will not let us use it. It says Error: Inhibited
If you have more than one phone then its probably flashing because the phone ID is the same as another phone on your system or not setup up yet with an ID just has two dashes (--). or you if you have more than one phone on the system and have more than 2 lines coming into the phone, they all have to be on line 1 together in the first port on the back. Communication between sets are done on line 1
Oct 01, 2010 | RCA 25413RE3 Corded Phone
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Sep 14, 2009 | Aiwa TV-S2011 20"
Error:Inhibited
unplug the phone, remove any batteries, and unplug the phone cord, wait ten minutes, and replace batteries, plug it back in and it should reset it.
Feb 15, 2008 | GE 29487GE2 Corded Phone
GE 29488GE2 Corded Phone Logo
629 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
