Question about Sharp Televison & Video
My Sharp LCD 26" TV shows most black and shadow colours as vivid blue, I have tried resetting the colour to factory reset but that didn't seem to help at all. It occurs on all channels and on 3 different consoles.
  • qmurray May 27, 2008
    I tried changing the brightness and the backlight settings but neither had any effect, neither did the brightness of the room. It is a VERY vivid blue and appears over mainly the darker areas between two colours. The included picture is from Friends and shows the problem
Sharp LCD 32 When I push the power button, the tv trys to come on then blink off and the power light just continues to blink
Posted on Dec 13, 2009
    Sergeant:
  • 395 Answers
The problem with LCD tvs are that they have back lamps that shine thru the LCD sceen. the job of the screen is to block the light of the different colors to make the picture. the problem is that the very thin screen can not block all the light. if the set has a back lamp setting turn down the back lamps and adjust the brightness control it should help a little. you my notice that the blacks and dark sceens look better when the room is fully lit and look much worse in a darken room.
Posted on May 27, 2008
  • Robert Johnson May 27, 2008
    I'm glad you shown the picture I can now advise you better, 1st reseat the LVDS cable inside the set. this is the multi wire cable that connects from the main board to the top of the panel. if that doesn't work replace the main board. if you give me the full model number I may be able to find the part number and where to get it. I wish more people posted pictures like you did it helps in the advice we give.
I have sony bravia KDL-40BX420 TV ,purchased 03 years back.recently got a problem with pictures & colour.It shows pictures with shadow & colours are blured.please give your feedback
I would check the menu settings and reset everything to default. if there are calibration tests in the menu, use them. Try more than one source for video.
May 22, 2014 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
There is a Video problem with my Samsung LCD. The sound is clear but Colour Balance Setting is disturb. The Colour is mixing with each other. Can You tell me the procedure for My TV Setting?
Before you set up try a reset
Resetting The Picture And Sound To The Factory Settings
as far as advanced settings are concerned, set the contrast backlight and brightness so you can see the best blacks without it looking too milky, the best whites so you can discern the whites and they aren't clipped, then look at colour balance if it looks wrong when you turn the colour off.
it shouldn't be very far out in factory settings. Operation How To Change The Picture Settings On Your LCD TV LCD TV...
May 12, 2014 | Samsung LN-S2651D 26 in. LCD Television
D colours are blue
try to hook up the connections with other port and replaced the cable connectors.
Jun 29, 2012 | Televison & Video
Colour on the tv is too green and red model 26av502U. Less then three years old. Reset to factory default settings per manual instructions and it didn't work
If you are using component cables change them out. It sounds like they're faulty. Try another device like a dvd player on a different input with different cables to see if the picture is still too red or too green. If so then the tv needs servicing. If not you can rule out the television.
Aug 13, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Blue instead of red colour afer replacing lamp in sharp xv-z2000
You didn't put your 3-D glasses on backwards, did you? :)
Seriously, if you are using the component inputs, be sure the three cables didn't get mixed up when you put the projector back. Otherwise, you might have an issue with the color wheel inside the projector, but I doubt it.
Dec 31, 2008 | Sharp XV-Z2000 Multimedia Projector
Hitachi 32LD6600 - When the TV has been on for abot 30 minutes the colours start to go blue/red and the picture is distorted,noting I do gets the picture to display as normal.
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
Mar 05, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Lcd tv picture wavy, black and white
by calling the tech they will answer your problem they will verify the problem in your colour circuit, the colour crystal or other related circuit could be your problem,the tech will give you the answer.good luck.
Apr 01, 2007 | Dell W2600 26 in. LCD Television
Televison & Video Logo
160 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
