Lamp assembly for rca
Called RCA they said to contact BestBuy to find the lamp assembly i need which is 270414...cant find it on your website..please help ..need to know pricing and how long it would take to get here after ordered...thanks
  • jack 07 May 27, 2008
    thank you very much
    Sergeant:
  • 395 Answers
Get it at www.vancebaldwin.com use part # 270414-B this is the bulb only and you will need to do some disassembly and reassembly of the lamp box. the price is $159.00 + SH.
Posted on May 27, 2008
RCA M50wh72s keep blowing lamp
do not touch the lamp during install and if somehow it did touch your skin, you have to cleanit with oilf free napkin and alcohol
Sep 07, 2014 | RCA Premier M50wh72s Rear Projection Tv...
My lamp went out on my rca and i dont know what lamo it is
your lamp for the M502h185 is the following
RCA 270414
that part is available several places on the interent and you can buy the bulb itself or the bulb mounted in a new housing (if yours is damaged) ... if your housing is ok and you can figure out how to mount the new lamp in it then its a little less to get only the bulb ..
here is one place that has both options:
http://www.260962.com/rca2.html
May 22, 2010 | RCA M50WH185 Television
Is there a led replacement bulb for the rca m50wh72s? the bulb 270414 lasts only 9mos tired of spending 120$ every time to replace this
No, LED light engines are different than Mercury Vapor lamp engines. They have different power supplies and different control boards.
Mar 14, 2010 | RCA HD61LPW165 61" Projection HDTV
I have a rca hd50lpw62a and its slow to turn on and dim when on.
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.If you hear strange noises like buzzing or humming noises it could be the color wheel which is a little disc that has a gamma of colors and spins at high rpms.When the light of the lamp goes through it creates the colors on your tv.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.Your part # for the lamp is 265866 and you can find it here: http://www.discount-merchant.com/RCA-265866-265919-269343-271326-270414-Lamp-p/rca-lamp-265866-26591-269343-r.htm Good luck and blessing for your house!
Feb 10, 2010 | Televison & Video
Rca model m61wh74syx1 is turning on with no pitcure and blinking 5 times then trying to restart
Hi,If your tv is around 1-2 yrs and haven't replaced the lamp it might be time to replace it.But if you hear clicking or continually trying to restart it could be your ballast ,which is the board that powers the lamp.The lamp you will need is the 270414 Found the lam pyou need here: http://www.discount-merchant.com/RCA-HD50LPW164-Original-OEM-Lamp-P-N-265866-p/rca-hd50lpw164-265866.htm?Click=48173 Good luck and God bless you!
Jan 05, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
RCA 50" dlp lamp dead?
There are many different problems with RCA televisions. One could be a color wheel. Another could be a bad ballast. www.Lamp-Replacement.com has a guide and solutions for your RCA lamp 265866 or 270414. The problem is most likely a bad ballast, which is supposed to pre-charge your lamp and ignite it. If you aren't even getting to that stage, you can trace the problem to another component or power supply.
Sep 01, 2007 | Televison & Video
Open Questions:
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
