Kindly required service code of philips tv model#14PT2115/56
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: code number required on philips
May I get the make and model # of the remote to help you more.
Posted on Jan 31, 2011
  • 11800 Answers
Celestial is a no name brand that is manufactured god forsaken places from parts bought from other more established manufacturers. Your model of tv's uses very old model Daewoo parts for the controller so check all the Daewoo codes stored in your remote. If none of them work then , as a last hope, do a full code scan - maybe the code set for another brand will match yours on the basic commands: on/off, volume and channel up/down.
Posted on Feb 05, 2011
Philips led tv 32pfl3008h frozen on logo screen
Sounds like a firmware fault. Contact the authorized service center for Philips in this case. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 03, 2014 | Philips Televison & Video
Someone gave me a Philips TV, but it doesn't have a remote. I have the serial and model number. They are 94492161serial #, model # is PL7125C107. Is it possible to purchase a remote for it?
Hello
Just buy one PHILIPS UNIVERSAL REMOTE CONTROL MODEL NUMBER [CL 034]. Philips is listed in its codes. Serial number and model number isn't mind. There are so manu codes for you to set it up. Code for philips listed is :
........... 0807 0022 0020 0422
................. 0122 0222 0322 0002 0520
....... 0919 0521 0621 0430 0247 0901
....... 0402 0408 0109 0210 0310 0715
You will get its catelogue and user manual with details along with that device.
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 24, 2011 | Philips Televison & Video
I have lost the manual for my Crest model Po5094-2 remote. I need the code for Philips model 29PT468A TV. Can you please help?
Hello
four digit remote codes for Philips are:-
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Four digit remote code for Magnavox are:-
PHILIPS-MAGNAVOX ..... 0062 0204 0207 0183 0226 0288
Three digit remote codes for Philips are:-
003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
Three digit remote codes for Magnavox are:-
PHILIPS/MAGNAVOX Codes: 183/ 184/ 208/ 213
NB: Switch OFF and switch On the tv with its front panel power switch each time before gointg to an other code.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Ok
Jan 15, 2011 | Philips Universal PH301S Remote Control
My Philips 60 inch rear projection TV model
Mute the volume and listen at the rear of the unit. You should be able to hear a fan running since these have hot-spots that require some kind of air movment to keep them from overheating. There are protective circuits that will shut down the power supply once a critical temperature is reached.
The second possibility is the power supply itself; these sophisticated units are very energy efficient but have components in them that age and lose their function over time. The main supply should be fairly easy to spot; it will have larger components on it, some cylindrical (capacitors), others block-like.
If the fan is running and it is still shutting down, this supply may need repair or replacement. Look for a part number on the board and inquire at the manufacturer's service center about those possibilities. Have your model & serial numbers of the set available too.
Sep 01, 2009 | Philips 60P8341 60" Rear Projection...
Need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
Jan 03, 2009 | Philips 47PFL7403D 47 in. LCD TV
Service menu code for philips 29pt6807 tv remote -rcla021 type
kinly send remote code for philips vaardaman model
Jul 15, 2008 | Televison & Video
Need Codes for a Philips universal remote
You did not specify model but you can try this. Repost if you have a specific model #.
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
3. Enter the 3 digit code from the code tables. Note:
4. With your device on, press CHANNEL Up. If the
equipment, try one of the other codes for your
brand.
SONY .................. 202 708 801
Dec 29, 2007 | Philips PH-DVD5 Remote Control
Tv. does not turn on sometimes? philips 63pf9631d/37
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Dec 01, 2007 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
