Hmm ok, have you been able to move a database like that one in the past without problems? Does it allow you to individually add the address to a new address label - from the database?
I am not certain it should work the way you are thinking it does.. please confirm have you been able to do it in the past?
Tim
Yikes that is very strange. After saving your database have you tried completely exiting out of the program, then re-opening it? This can sometimes cause the databases to be re-initialized and will allow you to access them. Give this a try while I continue to research this for you.
Thanks
TIm
If you'd like I can take a look at your screen and see if I can figure out exactly what you have going on, and how it works. If you want to do this please download this little utility:
http://www.teamviewer.com/download/TeamV...
Download it, open it up and reply back to this message with the ID and Password it gives you. Make sure to leave the utility with the ID / Password open though...
Once you write back with it I will connect to your computer.
Thanks
Tim
to micromatikal
This is my first attempt at printing label with this LABEL FACTORY DELUXE MANUAL.
I am at page page 102 in the manual with a small database made up of names & addresses
The next instructions on page 103 & 104 is to click the MASTER tap then click Open Database
. But when I click Database on the menue the Open comand is not avabale. And on the Database
Tool bar I get no responce from Open Database, My Database will open if I click on Edit Database Records.
And this is where I am stuck.
Thank You Bill Robison
Hi; Tim (micromatikal)
To answer your first question, This is the first time I have tried to do anything with this LABEL FACTORY software. Ihave been reading & working with this manual for over three weeks.
For the second question. If you mean have I closed the program & started from scratch? Yes many
times. I have at least a dozen topics printed from the programs HELP section.
If you can't help, I guess I will call a Geek to come in & teach me.
Thank again for trying
Bill Robison
