Question about Jenn-Air Refrigerators
I have a Jenn-air jcd2389de** The freezer side drips water (about 3 oz.) each day. The bottom of the freezer had excess ice buildup, which i cleaned out. I also noticed a clay-like substanced had deterated above the coils inside the back inside cover, but it still leaks! Do you know the problem? Bill
    Brigadier General:
  • 3,513 Answers
When the freezer defrosts all of the water flows into a tray in the rear of the freezer, behind the sheet metal, and then is supposed to drain down through a hose into the catch pan at the bottom of the fridge where it evaporates. What is happening is that the water does not completely drain before the freezer defrosts cycle ends causing the water to freeze in the catch pan blocking the drain hole. When the freezer again defrosts, the water cannot drain and overflows down into the refrigerator. This may also be caused by dirt in the catch tray.
The best way is to access the freezer coils which are generally behind the sheet metal in the rear of the freezer. That panel once removed will show the coils and the defrost heating elements, which by the way are working since the freezer is obviously defrosting. Locate the water catch tray below the coils and make sure both the tray and the drain hole are clean and clear of any dirt or pieces of insulation. Make sure also that the drain hose is clear all the way down and into the pan under the fridge. If you have found any reason for water obstruction, and have cleared it, reassemble the freezer panels and put the fridge back into use.
Please check the bellow links and the instructions therein to have a detailed idea regarding your query:-
http://www.ehow.com/how_2208484_that-leaks-water-down-refrigerator.html
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itleaks
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 04, 2010
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
Jenn Air JTB2488AE Freezer Top refrigerator. Water puddles inside the refrigerator space beneath the vegetable crispers. The ice maker has been turned off and the water still appears. The amount of water...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Jenn-Air Refrigerators
Water leaking from under refrigerator model
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 31, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
My Jenn-Air JCD2389DE* constantly freezes produce
Hi; Need more info. Does the refridg. cycle on and off during the day. When You say no matter where You set the tstat concerns Me to think that the unit might be
runing all the time. Remember the coldest place in the refridgerator is the bottom. Excluding the freezer compartment. Also are the door gaskets in good condition this will also cause the unit to run more
...alpharome416
Feb 23, 2010 | Refrigerators
I need to know how to hook up the ice makerfor a Jenn-air JCD2389DE
I'm pretty sure that the water hook up for most Ice makers are the same you have to find a water source that you can tap into. Most Home Improvement stores carry the kit which consists of a valve tap, connectors and vinyl tubing to be connected from the tap to the rear of the refrigerator.
Jul 16, 2009 | Jenn-Air JSD2789GEB Side by Side...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Js42sefxda jenn air freezer dripping water from the top vent
Check that the drain tube for the defrosted water is not plugged. Someone on here just the other day had the same exact problem, and that was the problem they had.
Jan 28, 2009 | Jenn-Air JS42SEFXDA Stainless Steel Side...
Water Leak at Defrost Time on Jenn-Air JCD2389G Side by Side
On the freezer side take the bottom drawer out and look at the back wall. You may get a partical view of the bottom of the cooling coils and directly below is where the water will drip from these coils. You may need a light and get your head back there to see the drain hole but it's there. This drain area could be filled with ice so, a hair dryer will do wonders. A tube with a little air pressure can unclog the drain. Pour a little water down the drain to make sure it's unclogged. Check this area often as this problem will happen again.
Dec 17, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
96 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
