Question about Hampton Bay 24002 Ceiling Fan
I have a Hampton bay fan with light and remote. The fan works fine but the light doesn't turn off, there is no pull switch only remote to control the unit. Thank you. AJ
    Problem Solver:
  • 9 Answers
With out actually being there to look at it sounds like the wire for the light at the light kit on the fan or at the fan box in the ceiling.
Posted on Oct 04, 2010
Ceiling fan light delay
How do you change the speeds? Pull chain ,dual control on wall or remote.
Sep 15, 2013 | Hampton Bay Dryers
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
Hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Apr 15, 2010 | Hampton Bay 52 In. White Redington...
Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Mar 01, 2009 | Universal Remote Control Hampton Bay...
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Dec 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Ceiling fan/light quit working with remote
Fan does not respond to remote, checked and replaced batteries in remote. No response, and unfortunately it is now well out o warranty but have the same fan in another room purchased same year 2003 which is moving along fine. Cannot find instruction book for either one. Please help. Thanks
Dec 11, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Remote control for the fan
So you have Hampton Bay fans and universal remotes? If so, then either the remotes are not programmed correctly or the receivers are not wired for the remotes. That is one bad thing about using universal remotes.
I suggest you go to Home Depot and buy one Hampton Bay remote, bring it home, turn of the breaker to the fans, and get on a ladder to get to the receiver. Check the dip switches, and program the switches on the remote exactly the same way.
(While you're at it, make sure the universals dip switches are set exactly the same.)
It should work properly after that.
Sep 13, 2008 | Universal Remote Control Hampton Bay...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
138 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
