Question about Sony RDR-GX355
Can I return default back to DVD 3 from DVD 1....It was changed by accident to DVD1....I want to get back to DVD .....CAN YOU HELP ME
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
In the operator's manual there are directions to the setup screen. You can select the set up menu and go item by item makign the choices you want. The manual is uploaded here on Fixya or on line through the Sony web site.
Posted on Dec 11, 2010
My Remote doesn't work, replaced the battery's works for the TV, but not the recorder, is there a default reset on the recorder? because I've changed the dvd3 to dvd1 so I'm not getting anything to display...
make sure remote and dvd select the same setting DVD1 on dvd recorder, so DVD1 on the remote, ther is some writing in the manual how to change the remote from dvd 1 to 2 and 3
Dec 31, 2010 | Sony RDR-HX825 DVD Recorder/HDD Recorder
I can't return to command mode dvd3 (default) from dvd1. Now my remote is useless and I can't find a way to bring up the main menu so I can get back into command mode dvd3.
Slide remote lower cover and look for DVD Command mode set switch, set it to DVD-3 position, your RDR-VX530 will accept remote commands.
Thanks.
Dec 21, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Feb 22, 2010 | Sony RDR-VX530 DVD Recorder/VCR
I CAN'T GET MY REMOTE TO WORK AFTER SELECTING dvd1 ON dvd MODE i WOULD LIKE TO RETURN THE SETTING BACKUP TO DEFAULT SETTING.
I finally got it fixed . I press the number one and enter key for about 5 seconds on the remote while I had the DVD player on and TV the
I press 1 again for 5 seconds and then press menu key till the menu
display on TV screen then I was able to change the settings back from DVD1 to DVD3. The DVD player now works fine
Nov 24, 2009 | Sony RDR-GX355
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Feb 01, 2009 | Sony RDR-VX515 DVD Recorder/VCR
DvdRDR-GX360
It´s is easy to solve. Your DVD was seted to DVD1. Push enter button plus 1 no remote control.
Now you are able to commnad your DVD and go to System Menu and change to DVD3 again.
After it, don´t forget to backup your remoto control to DVD3. Push enter button plus 3
Dec 13, 2008 | Sony RDR-GX300 DVD Recorder
Command mode
I did the same thing and lost all remote control to the recorder. Try holding ENTER & 3 in unison for as long as it takes (30 secs or more ) to view change on TV screen. This should get u back to system menu where u can change back to dvd 3 (default ) If doesn't work get a one for all remote and enter code 0533 which will get u in to the recorder command lines. PS enter & 3 worked 4 me.
Oct 22, 2008 | Sony RDR-GX300 DVD Recorder
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Aug 02, 2007 | Sony RDR-VX555
Sony RDR-GX355 Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
