Question about Onkyo TX-DS676 Receiver
How to i replace the recistor lebaled 2wk, 2-0.22 ohms
How do you find the fuse for blower
If fuses are not labeled, just test them all using test lamp to see if current is on both sides.
Jun 21, 2015 | Cars & Trucks
Oven doesn't turn on display indicates F4
HI. this error code is indicating that the oven temp sensor is damaged. it is not sending the correct resistance signals back to the main control board. This damaged sensor will need to be replaced, asap. Once replaced, the unit will operate correctly. This can , also, be caused by a loose wiring harness, as well. I would advise to inspect the wires that link the oven temp sensor to the main control board. if the connection is ok, replace the oven temp sensor.
If you have a multimeter handy, i will list the proper reading to check for.
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Nov 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
2005 DIAGNOSTIC ERROR CODE P0069, CRD ENGINE WONT
Are you traveling high ground like Rocky Mountain?
I will remove the ground cable for 4 minutes to reset all data in ECU.///clock and radio stations too : (
Let the ECU to relearn the local environment parameter.
Here's so info on how to prevent vapor lock
Ride with full tank of gas but NO TOP OFF.
Crack open gas cap carefully during rest stops to release / equalize gas tank pressure'
http://www.estes-park-information.com/vapor-lock.html
Good Luck
Jul 15, 2009 | 2005 Jeep Liberty
Model No: Hitachi 53UWX10B Rear ProjectionTV Problem: The picture is not aligned. There is a shadow (ghost) for the picture. I tried the "Magic Focus" or automatic convergence and still...
common problem. You need to replace both convergence ICs they are both STK392-110 and you will also need one each of the following six resistors . 3.3 ohm 1watt, 1.8 ohm 1watt, 2.7 ohm 1watt, 1.5 ohm 1watt 3.9 ohm 1watt 2.2 ohm 1watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions and free online tech support. Heres the link.
http://servicemanuals.vstore.ca/
Aug 07, 2008 | Televison & Video
Blue won't line up at the top in digital array
you need to replace both convergence ICs and the six 1 watt feed resistors. The ICs are both STK392-110 and the resistors you need one of each RK42 3.3 ohm 1watt, RK46 1.8 ohm 1watt, RK50 2.7 ohm 1watt, RK54 1.5 ohm 1watt, RK58 3.9 ohm 1watt and RK62 2.2 ohm 1 watt.
You can get replacement ICs and resistors at the following link with free instalation instructions.
Jul 15, 2008 | Hitachi 43UWX10B 43" Rear Projection...
My convergance on my Hiatchi model #53UWX10B has gone bad what components on which board should I replace. Can I get a service manual as well.
You will need to replace the two STK392-110 Convergence ICs and you will need 6 feed resistors as well 3.3 ohm 1watt, 1.8 ohm 1watt, 2.7 ohm 1watt, 1.5 ohm 1watt 3.9 ohm 1watt, and a 2.2 ohm 1watt. You can get replacement ICs and resistors at the following link with free instaltion instructions with pictures and you can also get your service manual for your model too. Heres the link.
Jul 14, 2008 | Hitachi Televison & Video
Blue convergence
Thats the classisc sign that you need to replace both convergence ICs. You will need two Convergence ICs STK392-120 and then six resistors they are RK42 3.3 ohm 1watt, RK46 1.5 ohm 1watt, RK50 2.7 ohm 1watt, RK54 1.5 ohm 1watt, RK58 3.9 ohm 1watt, RK62 1.8 ohm 1watt. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can repair the set yourself. Heres the link.
Jul 10, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Onkyo TX-DS676 Receiver Logo
173 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
