Question about Whirlpool Calypso GVW9959K Top Load Washer
F3 Kemore washing machine fault code
What is the fault code F3 mean for a Kenmore washing machine
  • Anonymous Jun 30, 2008
    Like to know what it means. Jimmy
  • tracynsc42 Jul 15, 2008
    what does f3 mean on whirlpool washing machine mean
Krazytech
  • 725 Answers
SOURCE: Not only is my asko washing machine leaking, the
F3 is a blocked drain...open coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Hope it helps if NOT let me know more about your problem... and I will help
Posted on Sep 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Fault code C1
"C1" is known as an Instantaneous Current Limit Error. This will occur when the Motor Controller detects a current spike of 26 amps or greater at the motor windings. Overloading the washer, excessive water and/or excessive suds can cause this problem.
The manufacturer recommends the following:
- Wash smaller loads and use the correct detergent (HE only for Calypso machines). NOTE: Make sure the HE detergent is not double or triple concentrated as this will also cause suds problems.
- Check for objects under the nunate plate. This is the wash plate. Sometimes clothing can get stuck under the plate and cause the motor to bind up. To remove the nunate plate, follow these instructions:
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Clothing can get tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Don't forget to put the tub ring back in.
- Check for objects stuck between the inner wash tub and the outer basket. NOTE: It is best to do this with the nunate plate removed. Use a flashlight to peer through the holes in the wash basket to see if anything is catching on the tub.
- Check the Motor Controller. You will need to determine if there is power getting the the board first and that the fuse on the board is good. If any components on the board are defective, the board has to be replaced. If you have power to the board and the fuse checks good, check for continuity between the Machine Controller and Motor Controller.
There is a tech sheet inside your washer along the interior cabinet (usually the front panel) that explains all these procedures to you. I would advise you to research the tech sheet for exact locations of the pin outs for the circuit boards. Its easier for you to view it rather than me explain it. If you need further assistance, please post back and let me know. I hope this helps you.
Posted on Jul 03, 2008
barkencoa
  • 3463 Answers
SOURCE: fault codes for indesit washing machine, the display shows F-08
F08 means that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
The only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
milten1
  • 1304 Answers
SOURCE: what does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Posted on Oct 20, 2009
SOURCE: My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models If the coin trap in the drain is clear of debris, try this. Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Just ran the machine now and fault cleared.
Good luck
Jurgo
Posted on Sep 13, 2010
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
    What does F3 mean on my Frigidaire stove when it sounds ...
    www.shopyourway.com > Manage My Life > Questions
    My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
    What does fault codes "F2" and "F3" mean on a Kenmore ...
    I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
    Oven error code "F2" and how to fix it ' AskGene.com
    www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
    Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
    Jan 27, 2016 | Kitchen Ranges
    What dose F3 code mean
    Amana Appliance Fault Codes - PartSelect
    www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
    Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
    Amana Gas oven Fault Code F3 - Appliance Repair Forum
    forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
    Nov 17, 2010 - 2 posts - ‎1 author
    Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
    Mar 15, 2011
    Range keeps giving error codes E0/F3 and E4/F3 and the ...
    Nov 22, 2010
    Replaced Sensor Still Getting F3 Error
    Sep 20, 2008
    F3 Error code on whirlpool Range
    Sep 10, 2007
    More results from forum.appliancepartspros.com
    Amana Fault Codes - Appliance Help O
    Dec 25, 2015 | Amana Kitchen Ranges
    What does the fault code e2 mean?
    Kenmore e2 code Washing Machines Questions & Answers ...
    www.fixya.com > Forum > Tags > e2 code > Washing Machines
    Kenmore washing machines e2 code related questions and answers. Ask yourKenmore questions. Get free help from washing machine experts.
    Jul 26, 2015 | Washing Machines
    What is the difference between codes 11 and F-11
    It looks like error code 11 is most likely to be associated with windows. F11 on the other hand is worth searching online.
    Jul 11, 2015 | Kenmore Kemore Whirlpool Sport Washer...
    Kenmore Elite Catalyst washing machine getting error F4
    See if this helps.
    http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
    Aug 01, 2009 | Kenmore Washing Machines
    What does F3 mean from my Kenmore Oven??
    f3 is a bad sensor part number WP8053344 this reads the temp. in the oven just like on older ovens had a thermostat.if you look into the oven you'll see it go here and look at picture
    https://www.repairclinic.com/PartDetail/Temperature-Sensor/WP8053344/722235
    go here to see error codes
    http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html
    Nov 13, 2017 | Kenmore Ovens
    Kenmore drop in range code F7
    Oven control beeps and Electronic control as detected fault condition.
    Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
    Program oven again.If fault recurs,record fault number.
    Press CLEAR and contact your Sears authorized qualified service agency.
    Oct 17, 2008 | Kenmore Kitchen Ranges
    Whirlpool Calypso GVW9959K Top Load Washer Logo
    311 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
