Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Television turned off and red light under lamp is lite. Televion will not turn back on. Is this just the bulb blowing out or is it something worse?
  • Anonymous Mar 24, 2014
    My LG televion cutts off than turns back on. How can I fix this problem. I brought the television from Wallmart 5 months ago
    Sergeant:
  • 171 Answers
This is a common problem for DLP TV's the average time for the life span is 6000-8000 life hours witch is a average time of 2-3 years of use if you have not replaced the lamp before I recommend you do that first and that should fix your problem and be careful when you buy a replacement make sure it is a Philips not a Generic I found the lamp you need and it is a Philips
http://www.discount-merchant.com/UX21513-LAMP-p/hitachi-ux21513-housing-h.htm
Posted on Oct 04, 2010
  • 4 more comments
  • stasi30 Oct 04, 2010
    The listing you have attached does not list the 50v500a as compatible. Is this still the correct bulb for my tv? My tv is LCD.
  • BONES420 Oct 04, 2010
    yeah this is the right one check it out I found one with your model listed on there
    http://www.discount-merchant.com/UX21511...
  • stasi30 Oct 06, 2010
    Thanks for all your help so far. one more quick question if you don't mind. I ordered the lamp that you found and replaced it. The lamp light is now blinking on and off and I still can't turn the TV on. Any advise would be appriciated. does the indicator need to be reset? Is something else wrong with it?
  • BONES420 Oct 07, 2010
    have you reset the lamp timer on the TV set I think that might be the problem try this and if it does not work you might have weak BALLAST
    "Reset the lamp counter hours of operation for the projector HITACHI 50V500
    1. Turn on the projector
    2. Press the “RESET” button on the remote controller for at least 3 seconds and the dialogue window will appear
    3. Select the “RESET” function
    4. The counter is at zero "
    IF THAT DOES NOT WORK TRY THIS
    1.Unplug the TV off the wall and hit power off and on for a few seconds
    2.let the TV sit for 2 hours so it could reset it self
    please keep me informed thanks
  • kal nas Oct 18, 2010
    I have encountered the exact same problem. Just wanna know if the fix worked. stasi30 please let me know.
  • stasi30 Oct 18, 2010
    Reseting the timer did not work for me either. it turned out to be a thermal sensor that went bad as well as the lamp.
No matter what i do after replacing the bulb, the red lights still flash three times and turns off my tv, and when the new bulb was first installed the screen stayed very did and still said to change the...
Red light flashing means their is a problem with the Lamp or around the Lamp,Lamp Fan,Ballast board.
Encompass Parts Distribution visit there website for Parts/prices
1-800-638-3328
Mats has Lamps for $99.00 1-800-628-1118
It is possiable that the lamp you have has something wrong with it.
Oct 14, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
It shutts off ramdomly the red lite blikes an have to what for green light to come on before it turns back on
Tv "LAMP" LED lite indication flashes or staying on?The tv projection lamp life is over.The projection lamp require changing.
Aug 06, 2010 | Panasonic PT-50LC14 50" Rear Projection...
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
My sony kds50a2000 failed lastnight. Bulb only?
There could be something else that caused the lamp to fail but if it has 6 to 8 thousand hours on it that is the expected life and it is not uncommon for a lamp to fail this way.
Mar 10, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic pt 50dl45 shuts off buy itself
You probably have a lot of dust inside.
Open the back panel and vacuum.
Also use compressed air to blow into the components. Do not blow into the fan on the right as it will get the dust inside the lamp housing.
Oct 15, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Changed bulb, still no pic
According to the manual the second lamp is indicating that the lamp cover is not closed
Jul 15, 2008 | Zenith E44W46LCD 44" Rear Projection...
Lamp out ...
remove front panel under screen, rove screws from lamp access panel cover. then remove the screws from the lamp assembly housing pull lamp housing straight out. install new lamp in the housing and slide the cartridge back into set replace screws and access panel cover.
Apr 09, 2008 | Mitsubishi WD-62327 62" Rear Projection...
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
1,077 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
