Question about Dryers
Dryer cutting off
My dryer stops working, it seems, when it gets overheated. It is about ten years old. I am not a mechanically blessed guy but I want to try to fix it myself. Any thoughts? Could it be the thermal fuse? Where can I get a manual for this dryer?
  • tntinwelcome Jul 30, 2008
    I have a ASKO T761 Electric Dryer (no condenser)...I can turn on with Fluff program and it runs. If I turn on with Low or Normal Heat, it runs maybe a minute and cuts off. As per the manual, I cleaned the filter and the fan. Both of which were not very dirty. There has to be a fuse or sensor that is defective or going bad. Any suggestions appreciated.
    Tina
  • 525 Answers
You may have a lint build up coating the windings of the motor. Not knowing what brand of dryer you have, all I can tell you is that you can attempt cleaning the motor to see if it helps.
Please disconnect the dryer from its ower source before servicing unit.
Posted on May 27, 2008
How to fix a dryer problem on a Haier wd combo
Dear Bob,
The answer may be easy, but the implementation?
Daunting!
About 20 years ago, two things happened to dryers.
One, "robots" began making them, and
Two, they became much more subject to overheating, as the automation caused more problems with lint build-up and subsequent overheating.
To combat the overheating danger of fire, more thermostats and even a fuse or two were then added.
I suggest you completely dis-assemble the dryer and you should find lint build-up inside the ductwork that is inside the machine that is blowing out the thermostat or a fuse.
A good cleaning should fix it for a year or two, depending on how often you use the machine.
God bless your efforts.
Apr 18, 2016 | Haier Washing Machines
HOW DO I BUY THE RISER DRAWERS FOR WASHER & DRYER 2 YRS OLD
try these guys , i just bought the parts for a ten years old ariston, but they cover all makes.
http://www.ukwhitegoods.co.uk/
Dec 12, 2014 | Samsung Washing Machines
Ge adora dryer model dhdvh52ef0ww runs for about 5 minutes then cuts off
Inside the back and the bottom of your dryer are several ( From 2 to 6 ) "overheat thermostat switches".
One of these is doing it's job really well.
These are designed to prevent your dryer from overheating and catching fire.
I suspect one of them is failing, and needs replacement.
Someone handy with electrical testing tools and mechanic's tools need to take it apart and check these to find the "bad" one.
While they have it all apart, it should need a really good cleaning inside.
Be blessed.
Mar 22, 2013 | Dryers
My dryer Kenmore DWJR ELE 2406028 FM64 stopped working. First it would stop at intervals. Now if I let the dryer cool, I can get it to run for a few minutes. It is over 10 years old.
Sounds like it is overheating. Clean your dryer vents and remember it is attached to GAS lines so don't pull on the cabinet. You can usually pop some hidden clips on the Dryer panels to remove them and access the inner workings of the machine.
Servall is a company which carries the dryer parts and may be helpful to you. They have a Website and sometimes have Diagrams you can use. You can also try the Kenmore Website for the photos.
If the dryer vents are clean, it sounds like a thermal switch is overheating and shutting the unit down.
Jan 25, 2012 | Dryers
Dryer keeps cutting off and has to be restarted.
There is normally a switch inside the motor that detects in turning at speed. That keeps the dryer running until it is either stopped, the door is opened, or the cycle is through. I am guessing that the contacts are getting bad on this switch.
Jan 03, 2012 | Dryers
I have a 6 year old whirlpool dryer (GEW9250PW0) that needs the sensor for the air flow and heat to be replaced approximately every 6-8 months. The repairman (certified) replaced this part last monday and...
Barone1997,
By-passing any devices on a dryer or any other appliance is risky as doing this can void warranties and could create a dangerous condition.
If then dryer is overheating, check the venting for excessive lint build up and clean the vent as well as any hoses or other vent piping. Also check and clean the lint screen frequently.
There is also a limit to the length of the vent line and the number of bends that the vent line should have.
It's possible that the dryer vent may be damaged or kinked, so check that too.
Apr 18, 2011 | Whirlpool Dryers
Goes on works about 10 minutes. stop.try to turn
Problem is the motor is going bad. Sometimes the motor can almost cost as much as a new dryer. An excellent little dryer that will last and work ghood for you is Roper, made by whirlpool. Any Lowes store has these. Hope this helps.
Mar 19, 2010 | Frigidaire Dryers
What would make a dryer stop tumbling? It is about ten years old now. It turns on alright but just won't spin anymore. Its a MayTag so shouldn't it work forever! LOL
Probably just a broken belt. Unplug the dryer and open it up (PIX BELOW) clean out the dryer and inspect the wheels idler and blower cage.The belt is probably gone after 10 years. Here are some repair pix
Aug 28, 2009 | Dryers
Should I replace t-stats and/or hi-limits and thermal cutouts?
i have fixed thousands of dryers over the years and the element shorting to ground is a rare ocurance.if you are loosing elements this fast it is due too your ducting as i think you know.and your replacement of the flex with hard ducting will surly aid in that cause.too answer your question,sure the thermo's will have been weakened but i have seen the same thermo's on 15,20 year old dryers ,so they can take some punishment.i owned an appliance repair buissness for ten years and after market wholesale thermo's were about 3$ each so if could find at that kind of price ,ok.other wise may be looking at 30 to 40$ and i dont see it making your dryer much safer then is with out new. God bless,hope that helps,tom
Jan 22, 2009 | Kenmore 64942 Electric Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
94 people viewed this question
Top Dryers Experts
