Question about Cameras
When pressing the power button on, i get LENS ERROR indication and lens does not open . I have Nikon S8000 digital camera
  • 231 Answers
Dear sir,
this happens when the clearance for the lense mechanism to open and close is being insufficient due to -small bits of sand or lint that may become get trapped in the mechanism which is commom while taking photos in open dust spaces.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned,if delayed the problem gets complicated....
thank you ..take care
Posted on Oct 04, 2010
Nikon j1 flash not working
Does the flash ready indicator also stay off, after you opened the flash and pressed the shutter release button half?
Because that could indicate there is not enough power in the battery to charge the flash.
If the light comes on, and still the flash does not fire, there would be a serious problem. My guess; that only can be solved at the service centre.
To be sure nothing else is wrong. Charge the battery first.
Then switch on the camera, open the flash, select fill in flash and press the shutter release button half. If the flash ready indicator lights, press the shutter complete and see if it works.
Succes
Jan 13, 2014 | Nikon 1 J1 10.1MP HD Digital Camera With...
Lens error in nikon coolpix camera
Have a Canon Power Shot sx20is. When I switch on the lens moves slightly then viewer says "lens error restart camera". Please help.
Sep 13, 2012 | Nikon COOLPIX S230 Digital Camera
Why doesnt the lens cover open all the way on my Nikon S8000 camera?
This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Nikon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Sep 24, 2010 | Nikon COOLPIX S8000 Digital Camera
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
Nikon CoolPix L18 getting lens error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Mar 29, 2009 | Nikon COOLPIX L18 Digital Camera
My camera worked fine one day, then it was in my purse. When I went to use it the light was on and the screen said there was a lens error. Everytime I try to turn it on now it makes a grinding noise and...
Hope you purchased an extended warranty. I've had two Cannon's with the dreaded lens error. Probably what happened was that while it was in your purse, somehow the power button got pressed. The camera powered up, tried to extend the lens, then stripped the gears or broke whatever mechanism extends the lens. The sad part is that if it's not under warranty, it probably not worth dumping $100.00 + into fixing it. Too bad, it's a nice 8mp camera with some pretty good reviews. I feel your pain.
Feb 22, 2009 | Nikon COOLPIX S200 Digital Camera
Nikon coolpix l2
I had this issue and I read on the net to hold the lens down on a table of some sort and apply slight pressure while pressing the power button, it should go right back in, It did for me!
Jul 29, 2008 | Nikon COOLPIX L12 Digital Camera
Lens Error
I have the same problem with my nikon coolpix s200. After 2 months the lens of my camera won't go inside. On the lcd screen stood lens error. I went to a shop with this problem. He took the battery out of my camera and press the off and on button for a while. Then he put the battery back in the camera and press the on button. The lens of the camera was now going inside en outside and inside and outside with a strange noise. And also on the screen stood lens error. Okey, the lens is inside the camera. But how can I fix this camera? What is the problem? What have you done? Please let know..!!
Jun 18, 2008 | Nikon COOLPIX S200 Digital Camera
Cameras Logo
66 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
