Question about Weather King 10AJA6001AH Air Conditioner
No cold air
My central air unit has no cold air and no is not running at all.
  • rayray361 Jun 27, 2008
    my weatherking airunit frezzes as soon as i turn it on
  • sadhuta Oct 27, 2008
    same problem....no cool air
    The repair man said the coil has to be replaced
    How much it is going to cost as we still have manufactuterer warrenty?
    But the contracor went out of business
    thanks
    dan
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Freezes up is only caused by either low on freon or low aiflow across the indoor coil, which could be caused by dirty or blocked filter ,,dirty fan blower wheel or pluged coil.
Posted on Sep 08, 2008
My central air conditioner is making a whistling noise in the inside unit when the compressor is running. It's not the blower because the noise stops after the outdoor unit shuts off. It's also not blowing...
If there is no cooling (meaning no cold pipes and not blowing cold air) then check the outdoor A/C for any visible/obvious issues; breakers not tripped, no debris blocking the outside unit from passing air through it, etc. If all looks ok, you can start checking some things inside of the unit if you feel comfortable doing so. Also, most indoor heaters have a higher speed/rpm for the fan when the cooling kicks on, and the heat runs on a lower speed/rpm.
Hope this helps James
Apr 05, 2011 | Heating & Cooling
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
Central A/C trouble in Las Vegas!
The contactor in the outdoor unit is stuck.You will need to replace the cooling contactor.I am sure it is wielded shut and thus will not turn off.
Sep 06, 2009 | Heating & Cooling
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
Central air unit only blows warm air , when set on cold
First check to see if your outside unit is working and you can here the compressor running. If the fan runs and the compressor does not you have a problem with the capacitor or wires burnt off terminals. If your not sure you know how to work on this please call a service tech ask for free estimate. If the unit compressor and fan runs you may be out of gas that meanns you have a leak. Either way you need a service tech. You can only go so far without the correct tools to work with. Russ
Jul 22, 2009 | Heating & Cooling
No cold air coming from the registers.
If your compressor is running outside (low hum noise) then your probably need freon .If the compressor is not running could be a bad cap or bad compressor
May 22, 2009 | Heating & Cooling
Central heat/air unit for home blows cold air
could just be heat trapped in ductwork for attic temp or from not running for more than a few hours.
Jan 13, 2009 | Haier HC48C1VAR Central Air Conditioner
My central air never kicks off
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Jun 09, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King 10AJA6001AH Air Conditioner Logo
130 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
